Made offer on 89 Catalina 30. Survey showed some issues but not of the next step. Should I keep looking, reduce offer (if so, how much)?
Boat looks great with all maintenance records and pretty well maintained. Here are the issues.
1 (biggest issue for me and probably only possible dealbreaker) About 22 blisters scattered about about 3-4 inches wide. There were records where blisters were repaired in 2007.
2 Engine (m25xp, 1000 hours) doesnt hit max rpm. Could be linkage adjustment or fuel delivery. Pedestal throttle lever actually hits knot meter. Could be easy fix.
3 Low oil alarm not working and no high temp alarm. This will cost about $200 in parts and can install myself.
4 Head not pumping.
5 20 year old main. Boom is low in cockpit and sail not going to top of mast. Learned from this forum that probably caused by bolt rope shrinking. Maybe sailmaker can get a few more years or just replace it?
So, what to do? Walk or offer less? Which of these things should figure into a lower offer? Thanks.
4 Head not pumping.
