Leaking fuel tank
Jan 31, 2012
56
Catalina 30 mkIII Santa Barbara
I have diesel leaking into the bilge. After inspecting I can only conclude it is coming from the bottom of the tank. The tank appears to be the original aluminum tank. My boat is a 1996. It seams early for tank failure but I have a few questions for anyone who has replaced a fuel tank. First there are 4 hoses coming out of the top. The fill hose, vent hose, supply hose (with a valve ) and a 4th hose I cannot identify. A new tank from Catalina direct is $400. This is the oem aluminum tank . Does anyone know of a Fiberglas replacement that may resist corrosion better? Any helpful comments are much appreciated.
The fourth hose is the fuel return from the engine.
Haven't heard of any fiberglass tanks. All of our skippers replace with OEMs, although there have been some reports of our Mark II boats being built with fiberglass tanks. http://c34.org/bbs/index.php/topic,4085.msg23343.html#msg23343
Call Catalina in Florida and ask them.
Good luck.
PS scroll down to reply #27 in that link, it gives a source of the fiberglass tank!
dj2210
Feb 4, 2012
337
Catalina 30 Watts Bar
Just replaced mine recently. The old tank had the manufacture's label on it. It was AFP and is now RDS in Florida. They still had the original drawings and made me a new tank for less than others. I called Catalina factory but they were having difficulty with getting the right part- go figure.
56
Thanks Stu and Doug. Doug, your tank looks exactly like mine. The mounting brackets are glassed to the hull. Did you just grind the old glass off the brackets to remove the old one and glass in the new one?
Mar 20, 2012
3,983
I have had great success with the por 15 tank sealer/liner.... i have used it on many tanks, large and small. it may be cheaper than a new tank, and if done correctly, will outlast a a new tank that is not lined with it.
but as with any epoxy, urethane, or paint type products, the prep work is the most important part.
the excess can be saved and used on other tanks in the future, which lowers the cost even more....
dj2210
Feb 4, 2012
337
Gregory, yes I used a 5 in grinder/sander. It didn't take much to grind but it does make a mess. I decided not to fiberglass it in like the factory. Instead made some straps to go over the tank and bolted it to some blocks that are epoxied to the hull. This way if I need to take out the tank in the future it will be easy.
jrowan
Mar 5, 2011
1,294
Greg, Before you go & pull out & replace your fuel tank are you positive that the tank is leaking? Because mine is over 30 years old on my original 1980 tank & it is holding fine (knock on fiberglass). Have you inserted a rag or paper or a sponge or something under the lowest area directly beneath the tank to confirm that is your leak source? Because the more common area of diesel leakage is from your fuel filter threaded connections not being tightened down, or clamps on the fuel lines being loose. There is a lot of vibration on everything connected to the engine that will manage to work itself loose over time. I would run your engine for an extended period of time under load, then check all clamps & hoses. It may just be a simple band clamp that is loose, & the leak may only be occurring when the engine is running & vibrating, making it harder to find the culprit.
Also check the seals around the injector pump, the fuel injectors, fuel lines & fuel filter housing first, & return lines before you pull your tank. Also in my opinion, I would stick with an aluminum OEM fuel tank if you do decide to replace it. Fiberglass tanks have been well known to get corroded from the corrosive nature of diesel & gas & can start to chemically break down over time. Google fiberglass fuel tank corrosion. Not sure if diesel is as corrosive as ethanol based higher octane gas is, but since the aluminum tanks have a 30+ lifespan, I would stick to what works. My 2 cents.
Jan 31, 2012
56
Doug and Jrowan
Thanks for the input. I have checked all the filter fittings and they seem dry. I concluded it was the tank as I see fresh diesel collecting under the galley floor and I can see moisture between the diesel tank and the water heater. I will go through it again with the engine running and look for leaks. If I replace the tank I will probably use the strapping to blocks for easy removal. (great idea).
Thanks again for all the good information.
dj2210
Feb 4, 2012
337
My tank was leaking ever so slightly at the bottom weld where the tang or corner was. The tank rests on the hull and the tabs are glassed in. I don't know if vibration and chafe was an issue but whatever causes leaks in aluminum tanks I decided it was just easier to replace.
Sep 17, 2010
26
Catalina 30 Anapolis
I've been getting oil in my bilge so I concluded the diesel tank must be leaking. I emptied it, pulled it and took it home for cleaning. I found no sign of leakage, and it held water over night. But going on 39 years, I decided I should replace the tank anyway, and I'm having a new one made locally.
Apparently in the early years there wasn't much standardization. My tank is rectangular, 36"x18"x7.5", and doesn't look like any of the pics I've seen posted. No hold-down tangs, just sat on a flat board at outboard end and a 2x4 block inboard. That block had collapsed and let the tank cant sideways, which helped convince me it was leaking.
Now I have to go leak-hunting again when the new tank goes in.
jrowan
Mar 5, 2011
1,294
Pencema,
If you're getting oil in your bilge then it is much more likely coming from a leaking oil filter seal, or from the engine seals being worn. The C-30 engine placement is good for even weight distribution being down low & centered in the hull, but it is famous for allowing bilge water to slosh around the bottom of the engine. Corrosion forms on the bottom of the oil pan & is well known to eventually rust out the oil pan. Inspect under the pan with a mirror. Or wipe under the pan with a clean rag. If you find a lot of oil clinging to the outside of the pan, it could have pin hole corrosion forming. Even if water doesn't actually slosh around & get the oil pan wet, condensation will naturally occur when the bilge water evaporates, & then condenses on the underside of the engine. I have known several C-30 owners who had to pull out there engines in order to replace the oil pan, which is a big job. Hopefully all you have is a loose oil filter, etc.
ps. Another place where oil can escape is the air return line which runs from the top of the valve cover back to the air filter housing. (This is how my 5411 is set up). The early Universal diesels were set up this way, but I'm not sure if the later M25 engines have this "feature."
Nov 24, 2011
95
Catalina 30 San Diego
I think many tanks don't last as long as others is due to water in the tank that isn't cleaned out. The pick up is off the bottom a little and won't get it unless the water gets deep enough but then will always leave some there. You will find it it the water separator. One reason you get a lot of water in the tank is not keeping the tank full as much as possible. Leaving a tank less than 2/3s full, especially in cool damp weather will allow condensation to build up inside the tank and collect in the bottom. Believe it or not, alga will also grow in the diesel too. Keeping your tank full most of the time will keep your tank from corroding as quickly. You will have fewer dirty fuel problems as well.
