Fuel Cans on Deck
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
We are getting ready to do our first "extended" trip out into the Gulf and I would like to carry a few fuel cans and extra water on deck just in case.
What is the best method of securing these containers on deck? I have seen boats with wood attached to the safety line stanchions and the cans attached to that. Is there any better way? I would appreciate some suggestions. Thanks
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
What you see is the most common. I have seen bladders strapped to the mid deck on some boats. I have a walk out transom and lash 2 fuel jugs to the stern.
ttac
Aug 9, 2010
114
Hunter Passage 42 Kemah, TX
I did not want to use wood myself. So I used plastic fence boards that I found on Home Depot's web site! They work well! And no painting or staining! I have one photo handy that shows them so I will add it here. If you would like more let me know!
Dean
Nodak7
Sep 28, 2008
1,256
Dean
Good idea T! Had not thought of that. Is it strong enough to hold them without flexing?
Jan 20, 2004
16
Hunter 41 Lake Texoma
I bought starboard from boatoutfitter.com and did the same thing. I couldn't find any other plastic long enough or solid... The starboard looks and serves the purpose..
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Decking
You could use that top decking that they use for decks and on top docks
and it never needs any work and is made I think of some kind of plastic but very strong.
I know some sailors from PG who replaced teak on their boat with it and like teak steps and toe rails with it,can get it from lumber supply or HD.
I have treated wood but yes I painted it white with stainless U-bolts and so far been good for a few years and it has worked well holding water and 6 fuel jugs on my trip from NY to Fl. out in ocean.
Nick
azguy
Aug 23, 2012
337
Catalina 22 Lake Pleasant
Just curious how much water you can hold in your tanks, that you feel the need for a few extra gallons..?
Nov 6, 2006
10,117
Water for abandon ship kit, offshore .. also in event tank gets contaminated with salt.. or a plumbing failure.. Good idea to have some separate water.
We are getting ready to do our first "extended" trip out into the Gulf and I would like to carry a few fuel cans and extra water on deck just in case. What is the best method of securing these containers on deck? I have seen boats with wood attached to the safety line stanchions and the cans attached to that. Is there any better way? I would appreciate some suggestions. Thanks
We lash our fender board to the lifeline stanchions. Cans to that.
Nov 5, 2009
62
Hunter 34 Quebec
In many places you need jerrycans anyway to carry water between shore and boat, so might as well keep them filled! + for emergency,contamination,etc.
Hunter 410 Grand Rivers, Kentucky
PIC board is available at any lumber yard. 4 x 8 sheets. Cut strip the size you need and save the rest for other projects
Jun 7, 2007
28
- - Newport Beach CA
I attached stainless steel tubing between the stanchions. This is obviously more expensive
but when the Jerry jugs are removed, the tubing blends in with the boat and not really
noticeable.
Jul 1, 2004
567
Hunter 40 St. Petersburg
Some really great ideas shared here.
I just wondered why you would want to put HEAVY water on one rail? Why not down below? Maybe low and near your CG?
Diesel I understand. But water?
35+ lbs. per can at the end of a really long lever arm? I don't know man . . .
Nov 5, 2009
62
Hunter 34 Quebec
If you change them from one side to another depending on which tack you are on, they actually improve performances!
...I know, nobody does that. But then there is rarely space down below for all those 20L tanks when cruising
SABA
Mar 24, 2009
2
Hunter 38 Sarasota
Dean,
This is the most esthetic installation I have seen. It appears that you have used one U-bolt on the stanchion and countersunk the plate. Did you find one this sufficient? Also, did you pad the stanchion where the U-bolt was attached? More photos would be great as well. Thanks.
Bob
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
I have considered something like this, but I am concerned about weight on the lee rail and interference with the jibsheets. Since I usually single hand sail, I keep the jugs under the dinette table or in the rear "berth" area. I suppose the weight on the lee could help the heel in light air.
Nov 6, 2006
10,117
Splax.... Ya know that starboard list that the 34 settles into... some fuel up there on port will help that !
Mar 3, 2003
710
Hunter 356 Grand Rivers
I used a 1x3 and used stainless u bolts one per stanchion. I routed 1-1/2" linear slots for 1-1/2" nylon straps that went over the top and around the jerry can and also around the middle. I used the plastic 1-1/2 " connectors to strap them together. I put stainless acorn nuts over the exposed threads of the u bolts. Worked out great for 5 jerry cans and 25 extra gallons of diesel. I use a shaker type siphon and it will transfer 5 gallons in 1 minute and 40'seconds.
ttac
Aug 9, 2010
114
Bob I will try and post more photos when we get back to the boat! This has been working well for over a year. And we have been in some rough seas with waves hitting them and no problems!
Dean
