Planning to change out sanitation hoses on 41DS Has anyone done this ?
how difficult is it? any tips on how to go about doing this?
Sailor, beautiful boat you have there what year is it! Do you have electric toilets? What made you decide to change out your hoses?Planning to change out sanitation hoses on 41DS Has anyone done this ?
We have not experienced that with our 2006 41DS but it has electric fresh water heads which might be the difference. Looks like an ugly job though.its a 2006 sanitation hoses have permeated bit of smell in bilges... no to electric
heads..
Interesting that when we bought our 41DS we were planning on taking it to the Puget Sound but changed our minds and went south instead. Did you buy her new?
Did the job last year on our 2005 H44. Toughest part of the job was getting old hose out as it was threaded through the floor and bulkhead stringers and had become brittle. Could not take it out in one piece and had to cut out various sections. I wish I had flushed out the old hose more thoroughly as each time I cut it the residual drained into the bilge and it took awhile to clean out. Threading the new hose which was thicker but much more flexible was significantly easier.Cover the ends of the hose with a plastic bag and seal with duct tape. Keep the nasty inside.
While a hair dryer might work, there is a much easier way, which is foolproof.The dificult part is inserting the fittings into the hose. Use a hair dyer (dont use heat gun)to heat up the ends/use gloves hose gets very hot. You may have to reheat a couple of times. A bit of lubricant may help as you have to rotate the hose around the fitting. make sure you rinse and drain old hoses and wash hands frequently while removing old hoses.
How do you do that once the hose is snaked around, ending at the right spot, and cut to the correct. What pot of hot water are you going to be able to get into that spot and get the hose into?While a hair dryer might work, there is a much easier way, which is foolproof.
Simply boil some water in a small pot,
Stick the end of the hose in the hot water for about 1-2 minutes.
It totally softens up the end enough to slip onto the new fittings.
there is always enough slack in the end of a hose to turn it vertical.How do you do that once the hose is snaked around, ending at the right spot, and cut to the correct. What pot of hot water are you going to be able to get into that spot and get the hose into?
Sounds good but more likely you are going to burn you hand.
Is that the hoses may get hung up while trying to [pull it thru from holding tank to heads. I was hoping someone with a 41DS had already done this job and could tell me if there are any such concerns.. From my perspective it looks like Hunter assembled the boat Hull around the hoses!there is always enough slack in the end of a hose to turn it vertical.
I have found on some occasions to dump the freshly boiled water into a large mug works as well.
It doesn't take much time to soften up the tubing. The thing is by putting it in hot water you are getting inside and on the outside walls of the hose. It really does work very well.
Sailor that was my thoughts when I looked at how the hoses were run! Good luck to you and I may be asking you for advice in the future!Is that the hoses may get hung up while trying to [pull it thru from holding tank to heads. I was hoping someone with a 41DS had already done this job and could tell me if there are any such concerns.. From my perspective it looks like Hunter assembled the boat Hull around the hoses!
All the tips that have come in will be helpful thanks a lot fellas.
Although not the same boat, some long runsIs that the hoses may get hung up while trying to [pull it thru from holding tank to heads. I was hoping someone with a 41DS had already done this job and could tell me if there are any such concerns.. From my perspective it looks like Hunter assembled the boat Hull around the hoses!
Mar June this is your neighbor Kite Runner. You know my history and where I've worked for 37 years of my life. I've run more electrical conduit, copper and stainless pipe, bundles of signal wires and so on. I have the proper lubricant to your avail, devices to feed to or pull from A to B and a few good suggestions that might win this battle. Throw a case of beer my way and we'll talk... or surrender those pics of me up the mast installing radar deflectors!Planning to change out sanitation hoses on 41DS Has anyone done this ? how difficult is it? any tips on how to go about doing this?
thanks for advise. I have the correct connector for the hose has barbs on it so hose wont slip off. used it to do same job on our old boat (91 37.5) . i was hoping to find from another 41 owner if there any place that the hose pull thru without major surgery to floor . will use detergent for lube good ideaAlthough not the same boat, some long runs
Here is what you should do.
Make a bushing the exact ID of the hose. Wood works great
Make it about 3-4 inches long
Shove it half way into the end of the hose you are removing
Then put screws through the hose Into the bushing
Now connect the new hose to the old
Now, you just have to push & tug like a madman to force the new hose along the old path
Cover it in dish washing detergent, as it will make pulling the new hose in much easier
thanks for offer captain G. if i run into problems Ill give you a callMar June this is your neighbor Kite Runner. You know my history and where I've worked for 37 years of my life. I've run more electrical conduit, copper and stainless pipe, bundles of signal wires and so on. I have the proper lubricant to your avail, devices to feed to or pull from A to B and a few good suggestions that might win this battle. Throw a case of beer my way and we'll talk... or surrender those pics of me up the mast installing radar deflectors!
You can find me at slip O-37 or just whistle! You know how to whistle don't you?
There are 2 reasons that this works well:thanks for advise. I have the correct connector for the hose has barbs on it so hose wont slip off. used it to do same job on our old boat (91 37.5) . i was hoping to find from another 41 owner if there any place that the hose pull thru without major surgery to floor . will use detergent for lube good idea
