I did a little experiment recently that might be interesting regarding multiple solar panels and partial shading.
I did this because two people who’s opinion I respect use a separate MPPT controller for each panel in some configurations and the reason is that this should work better if you have a situation where you are likely to have shade on one of the panels (like on a sailboat).
I was surprised at the results… maybe just the old panel I used for the test?
Anyhow, you hear that partial shading on a solar panel significantly reduces its output – and it does. What I wanted to look into a little more was how much benefit you get if you have two panels and one has partial shading and you use one MPPT controller for both panels or a single MPPT controller on each panel.
I hooked up a 5 watt solar panel that I picked up with a used boat purchase so don’t know much about it and measured current vs. voltage for this panel for both full sun and partial shade (see the picture for partial shade – its just some electrical tape). The setup is simple, just a power supply that can either source or sink current with a 1 ohm resistor in series to the solar panel. A hand held DVM is used to measure the voltage across the 1 ohm resistor (current is the same as the measured voltage) and also measure the actual voltage on the panel.
What I measured somewhat surprised me as I expected to see more benefit from using a separate MPPT controller on each panel than I did but this may be due to the particular panel I used for this test??
I took this single panel and put in full sun with a way to “force” the voltage (with a power supply) and measure the panel current. I then put a piece of electrical tape on the very same panel right after I did the first test (so the sunlight was the same) and repeated the measurement.
This is the panel with the partial shade:
The image below shows the voltage and currents I measured (put in a spreadsheet to calculate power).
Volts = forced panel voltage
I full sun = panel current with NO shading
Partial = panel current with the tape across it (partial shading)
Pfull = power generated by the full sun panel at the Voltage (i.e., Volts * I full sun)
Ppartical = power generated by the partial sun panel at the voltage (Volts * partial)
Ptotal = Pfull + Ppartial at the forced voltage
What you see from this actual data is that this particular panel has a peak power 4.81 watts at 12.75 volts for full sun and this is where the MPPT controller would also operate the single panel. The peak power points are shaded yellow in the figure above.
What you see when the tape is put on the panel is that the current is reduced considerably (from .378 amps down to .228 amps at 12.75 volts). However, the current output does not change as much with voltage as for the full sun case.
Now the interesting thing is that this panel had a peak power at 12.75 volts for the full sun. But the peak power shifted to 13.75 volts for partial shading. This would imply that an MPPT controller per panel (when there is more than one panel) is going to give maximum power, and this is true.
But.. look at the total power you get from using two solar panels (one shaded) with either one or two MPPT controllers.
One MPPT Controller for two panels (one shaded):
Peak power is 7.7265 watts @ 12.75 volts (see Ptotal in the spread sheet)
Two MPPT Controllers on two panels (one shaded):
Peak power full sun panel 4.8195 W @ 12.75
Partial shade panel 3.025 W @ 13.75
Total Peak for both panels 7.8445
I.e., if we have two identical panels and one has partial shading, using an MPPT controller on each panel only gets you about 1.5% extra power out of the panels – and you may actually get worse since you now have the operating current of two controllers vs. one.
Not what I expected.. I thought I would see a lot more benefit using an MPPT controller on each panel. Maybe its just the old panel I tested?
FYI, I also looked at the open circuit voltage for this panel for different shade conditions. The tape I put across the panel only reduced the open circuit voltage from 17.83 volts to 17.69.
