The main halyard winch, mounted to port of the companionway on the cabin roof, has pulled loose. It seems that the PO or Hunter mounted the main and jib halyard winches (old Lewmar single speed 7s) using 5 sheet metal screws (#8 to #12 and 3/4" long) that were screwed into just the 1/2" to 3/4" of fiberglass that covers what seems to be imbedded backing plates.....not into the backing plate - just into the fiberglass over the plate.
And they didn't even do a good job of it - as shown in the photo of the main halyard winch base and all of the 'extra' holes drilled into the fiberglass but not deep enough to secure to the backing plate......
Is there actually an imbedded metal (aluminum?) backing plate for these halyard winches either side of the companionway? My probing seems to indicate some metal under about 5/8" of fiberglass.....
Is this the Hunter standard i.e., to use 5 sheet metal screws screwed into just 3/4" of fiberglass to mount the halyard winches?
The starboard jib halyard seems strongly mounted using this method but 2 of the 5 screws have pulled loose from the fiberglass on the main halyard winch so I need to figure out a good repair and then probably apply the "preventive fix" to the jib halyard winch.
What is a good way to repair the stripped out screw holes for the main halyard winch? I've got a couple ideas but would like to hear what others might do or have done.
Thanks!
Thanks!
