This morning when I woke up to let the dog out I noticed the bottle of -50 West Marine Pure Oceans propylene glycol sitting on my BBQ grill was frozen solid. The air temperature was approx 4 F.. I reached over and grabbed my point and shoot to make this video.
Once again I want to stress the importance of NOT DILUTING -50 RV/Marine antifreeze! While the label rating is a rather misleading "-50F" this is a BURST POINT for metal pipes. The burst points are significantly higher for plastic fittings and pipe or thin walled copper like is found in our heat exchangers. While at 4 F the -50 had not yet begun to "expand" as you dilute it the temp at which it does exapand rises. Two years ago I had a DIY split a Universal M-25 HX by sucking in a full TWO gallons and shutting down the engine when he "saw pink".... Seeing "pink" at the exhaust tells you little to nothing about its level of dilution.
Six weeks ago I winterized a Grand Banks with a large Ford Lehman diesel & Sea Frost refrigeration system. I "saw pink" at 9 gallons of AF. It was not "undiluted" until 16 gallons had been run through it! This was all confirmed with the use of a sight refractometer as measured with an exhaust outlet capture of AF.
Every spring I see and hear of boats with freezing problems and this can only be attributed to the -50 PG getting diluted by water that is already in the system. Pipes, seacocks, heat exchangers, valves, water heaters and even a water filter. I have seen all of these items SPLIT and destroyed.. When you suck in AF the displacement is not 1 gallon of fresh to 1 gallon of AF it mixes in the system thus diluting the -50F burst rating and moving the burst point upwards.
What comes out your exhaust or your faucets should match exactly what came out of the bottle, if you are in a cold area, and if you don't want to worry about your HX or engine.
DISCLAIMER: Please ignore the poor quality of this video, and my stumbling of words, as I had not yet had my coffee nor thought about what I would say. Please understand that this was a one-take deal at 4F with flip flops, and shorts on.........
