cable rubber boot
Oct 29, 2005
2,366
The black rubber cable boot of my Raymarine autopilot blacken my fingers when I touched it.
How can I stop the boot from deteriorating?
May 1, 2011
5,572
Pearson 37 Lusby MD
Ken, I had the same problem and never did figure out how to stop the deterioration. Now I have a type 1 linear drive, so no more bad boot.
Jan 4, 2006
7,838
Hi Ken,
Try Meguiar's vinyl and rubber cleaner. It's worth a try even if the rubber has already started to deteriorate.
I've used this cleaner on rubber snaps and everything else that doesn't move on the boat. Where it really works is the vinyl rub rail around the boat. Could pass for new after 14 years and very easy to clean after a long winter.
Oct 29, 2005
2,366
Ralph, thanks for the idea. Will shop for the Meguiar stuff.
Hunter 34 Alameda CA
The sunlight is probably breaking it down. A lightproof cover would help. Maybe make one out of a piece of bimini fabric.
Nov 24, 2012
586
Another product that I have used with a lot of success is Woody Wax. Lots of uses including plastic parts (not eisenglass) metal and non skid.
Ross
Jun 15, 2004
14,693
Paint is always an option.
Blitz
Jul 10, 2007
728
Seidelmann 34 Atlantic Highlands, NJ
Yep, common issue after only short term use. They will warranty it but more than likely you'll need to remove the entire drive wire to put a new boot on and It might not be worth if it's going to fail as the first one always does.
Oct 29, 2005
2,366
Now why didn't I think of that??! Great idea Allan. I'm handy with sewing machine and have small pieces of Sunbrella. I'll still clean it then wrap it up. :D
Oct 29, 2005
2,366
Yah, removing the boot is a pain. I've to pull the cable out through a pack pipe(hand hold). :doh:
