I have a problem that is causing an unsafe situation aboard my boat that is persisting despite my efforts to resolve it. My Charge controller is transmitting a signal that interferes with channel sixteen as well as other lower numbered VHF channels. It does not transmit an interfering signal with the higher numbered channels. The signal is approximately 12 feet from the controller then begins to fade out. It is a loud signal sounding much like the radio civic defense warning signal transmitted over TV and Radio. The signal goes away at night, or if the panels are covered. It is heard on handheld as well as fixed VHF. These signals are loud and do not allow safe monitoring of these channels. I have to resolve this issue.
I have placed Ferrite Snap on noise filters on the cables, singular and in pairs, and finally on all four cables with no results. I have rewired the charger with new professionally assembled cables from the charger to the batteries, as the old ones were not sufficient to go to the batteries when I moved the box aft, away from other electronics. Nothing has helped. Has anyone else had this issue? I posted here a few months ago, and that led me to contacting BZ.
So I contacted Frank, a technician with BZ products a few months ago and was told that perhaps a CB Noise Filter wired into the system might help. I have acquired one, but am unsure how to hook it up. I will need to know specifics as to AWG, Connectors, Fusing, and Recommended Location of the filter. They have not yet responded to my request for this information. I was hoping someone here could help with this problem
The filter: POWERLINE INTERFERENCE FILTER, EMI-P30A 16 VOLT, 30 AMP MAX. There is a Radio positive, a radio negative and a batter negative terminal post on the filter box. How do I ware it? is this the appropriate filter?
Solar Power system Specs:
MPPT 500, Mfg. 2/13 connected to two solar panels, wired in series. The panels are Suntech 190W Mono-Si.
Cabling and connectors is professionally made. I can give specifics and photos as needed. I can also supply video of the signal if that would help. System was professionally installed in Early 2013, prior to my purchasing the boat in May of this year. Handheld is an IC-M920, Mounted VHF is a Standard Horizon Eclipse.
Please advise and Fair Winds!
Keith
Keith
