A couple more things somewhat unique to the 26S that worked out well..
I like the outboard well on the the 26 classics as it puts the outboard in a good position for accessing it when your sitting in the back and it also minimizes the "moment arm" of the weight of the outboard sticking off the back of the boat. A bunch of years ago both Sumner and I put transom risers on the back of the boats but did it slightly different. Both use an extra long shaft and I raised mine 2.5 inches, Sumner raised his 5 inches.
Anyhow, this really has worked out well. I can fully rotate the outboard which is nice to get in the slip at the marina I was just in, plus it puts the prop 2.5 inches lower than the stock long shaft, I pretty much never have an issue with the prop coming out of the water.
But.. I didnt really have a good way to keep the outboard in the up sailing possition (which resulted in my busted off shifter) so I got started on this next mod below. There is already a tether on the outboard used to pull it up, Ill just use this to also tether the outboard to one side - so it will stay put no matter how wild I sail that boat..
Other unusual thing is this trailer setup. Its got a low stop and a bow roller underneath. The old "high stop" is now just a guide. The picture below shows where I position the boat with the trailer in the water.
I didnt do any bumps or iterations, just pulled the boat out. The picture below shows where the boat ends up on the trailer. Its an amazingly easy boat to trailer given that it is 26 foot long.
One more of Havasu
