filling large joints
1,970
Endeavour 42 Cruisin
The shower floor pan has a gap between it and the shower wall of about 3/8". I cannot keep the caulk adhering to the whole joint to seal it tight.
What do I do here?
Buy some (thin) line, fill the gap with line and then caulk over that.
Nov 2, 2010
114
Precision 28 Ashland, Oregon
[Apologies for the OT humor - can't help it sometimes...] Filling Large Joints? He must be from California! (Cheech & Chong, paraphrase)
Ha ha. :dance:
I just returned from a trip to British Columbia, drove through Oregon. Better "stuff" there. It rains all the time, except for when I drove through. Whew. :eek:
Nov 21, 2007
673
Closed cell foam "backer"
We built a log home in Montana a number of years ago. When they apply the chinking to seal the gaps between the logs, they used what is basically a sanded caulk. They apply the chinking over a closed cell foam "backer rod". The thin line would do the same thing, but the foam would not absorb or hold moisture.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
What do I do here?
if it is a horizontal gap.... just make a teak trim board and put a rabbit in one side that is wide enough to lap over the 3/8 gap making sure the rabbited side is down and the thick side is on top....put some ss oval head screws on 5 or 6 inch centers in the thick part of the trim board and us a sealer on the contact of the trim to the wall surface and you will have created a drip rail ....
hope this helps
regards
woody
Oct 15, 2009
220
catalina 320 Perry Lake
You can get a roll of round foam filler strip at the hardware store. I can't remember what it is called but it is used to fill gaps before grouting tile, or caulking joints. It comes in different diameters depending on how wide the gap is. Very inexpensive.
Nov 26, 2008
1,970
A big part of this issue is the bit of flexing between pan and wall. Both are fiberglass, what caulk will adhere well and flex without tearing away from one of the surfaces?
Jul 18, 2009
274
marine clipper 21 ft santa ana Southern Lakes,Yukon
there is a chalking designed for large gaps and staying flexible with good adhesion, it will stretch 500 percent AFTER DRIED APPLICATION...
http://www.sashco.com/hi/bigstretch.html
The product is called "BIG STRETCH"
ANOTHER POSSIBILITY.."MARINE GOOP"...???
Nov 13, 2011
166
Oday 23 New River Az
Fix the gap. A piece of SS shiplap will work just fine, and is sort of what it is designed for. A picture will get you a much better solution though.
Oct 30, 2011
542
klidescope 30t norfolk
Backing rod
The foam stuff they sell at hardware stores is called backing rod. Kind of a thiner version of a noodle the ones kids swim with
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Why not butyl with a trim piece? The stuff stretches like crazy. Take a look at Maine Sails picture of the cleat getting pulled off and how much it stretches while still adhered. You can kneed it into a rope like shape and work it into the joint.
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
(yeah - pix please)
This is what I would do, too. You want to reduce the open gap to a reasonable minimum, then caulk that. . Besides the shiplap or other wood trim shapes, big-box home building stores will have a good selection of vinyl, aluminium or chrome strips which could be suitable.
