A coupe of issues/thoughts that may be pertinent to his dilemma ....
1. Cetol's formulation of UV stabilizers is probably a nano-sized ferrous oxide ... added to protect the WOOD underneath the Cetol from UV damage. Its the destruction of the upper surface layer of wood cells thats the goal of UV stabilizers in 'clear-ish coatings' for wood.
2. That leaves the Cetol and other coatings 'plastic' components, especially the surface layers, vulnerable to UV damage ... because the 'depth' of the UV compound isnt all that 'deep'/thick on the surface.
3. FLAT surface 'finishing' of the coatings, especially transparent or translucent coatings, do not produce 'lensatic' concentrations of the incident light ... like how a magnifying glass does. If his surface is not close to totally FLAT, then this 'lensatic' effect will allow UV damage faster in some areas of the coating than when FLAT. The answer to that is to learn to 'lay down' a dead-smooth final coat, or hand-rub and/or power buff the final surface with 3M Finese-it™ then 3M Perfect-it™ to FLAT if the final coat isnt flat - called 'finishing for good reason'.
4. He might want to 'experiment' also with clear high 'SPF number' cosmetic sunscreens that are applied to skin as a continual temporary method ... of course he's got to also experiment to see if any of these will be 'harmful' to the surface finish.
5. There's always the possibility of using canvas / fabric covers over his brightwork.
6. If the surface/clear degradation is the issue, he might want to consider a 2-part urethane 'clear coat' over his cetol if what he's trying to protect is the cetol .... automotive clear coats are quite robust vs. UV. Before the advent of Cetol and other modern catalyzed coatings, many varnish-aholics would use 2-part clear over 'primo-primo' varnish jobs for protection ... protection of the varnish.
7. If the above doesnt sound 'interesting', suggest he change to the more modern 2-part base + 2 part clear such as Bristol Finish or Honey Teak. Ive abandoned the use of all but Honey Teak but still have to recoat with the catalyzed clear every few years (since its an ACRYLIC-urethane co-polymer system it can be power-buffed back to brilliance).
HT -
www.signaturefinish.com - (expensive)
I have a boat with 'acres' of brightwork.
