I have a 1982 Catalina 30 When under 3/4 to full power on the engine there is a loud whining soud from bebeath my feet , would this be the cutlass bearing?
Have you fed the dog recently?I have a 1982 Catalina 30 When under 3/4 to full power on the engine there is a loud whining soud from bebeath my feet , would this be the cutlass bearing?
say what?Sorry to hear about your issue. Hope you can find the issue. The internet is not an appropriate place to diagnose sounds, smells, tastes, or electrical issues with pictures but no wiring diagrams.
The best advice is to be methodical. Take each of your "possibilities" one at a time. Really, only ONE at a time.
Someone gave me good advice a long time ago: when you have issues for changing filters (for example), try only one fix at a time, 'cuz if something works or doesn't, you simply won't know which one it was (or wasn't).
Good luck.
I was going to say it sounds like a teenage son still living in the basement with a gland problem.I have a 1982 Catalina 30 When under 3/4 to full power on the engine there is a loud whining soud from bebeath my feet , would this be the cutlass bearing?
Does it also happen when not in gear? If so, it could be your fresh water pump bearing, assuming your engine is fresh water cooled.I have a 1982 Catalina 30 When under 3/4 to full power on the engine there is a loud whining soud from bebeath my feet , would this be the cutlass bearing?
Tie up nice and tight, put it in gear, put it at high revs, and head below to see if it's forward or aft of the coupling.No only in gear and at hi revs
