My 2004 h386 has a Hunter-installed 16k btu (left hand) heat and air unit. This unit has developed corrosion in the condenser coil area that was undetected until it started leaking from the cooling water line that is integrated with the coils interior of the condenser housing in the unit. It appears that repair is synonymous with the rebuilding unit, which means replacing new seem a better choice. The problem appears to be that this unit is no longer made and a larger unit cannot be fitted into the a/c area (dinette settee).
So, my question: is there a company that rebuilds and/or manufactures units that fit the specs and size of this 10 year old unit? Or, might some of you have another solution.
Many thanks.
Many thanks.
