Trimming new ports or not?
126
Hunter 34 Holland, Mi
Hi, I have purchased a Hunter 34 and am working on a few things. What I need to know is if I should trim the new Beckson ports I'm installing or leave them factory length. If left they will have a 3/4 inch over hang from the cabin side. Any thoughts?
Nov 6, 2006
10,216
My preference is for the "tubes" to be flush with the outside trim. Keeps ya from banging ankles and keeps folks from using them as a step and breaking the port.
Mar 27, 2012
312
Seaward Fox Washougal WA
I agree! They will also scrape your achilles!
WayneH
Tartan 37 287 Pensacola, FL
We've used a bandsaw and a fence to cut down the beckson ports. Accidentally ordered 2" ports when I needed 1" ports. Would have sent them back but ran out of time to return them and get the correct ones back so.... snip. A tiny bit of trimming afterwards and you can not tell which are 2" and which are 1". So go for it. Just leave enough sticking out for the outer ring.
Sep 5, 2007
689
MacGregor 26X Rochester
Trim them flush. And use the correct adhesive (DC 795, if memory serves).
I prefer to not have the fasteners showing, but that's just a matter of personal preference.
Pic is of the factory port in my H340. I also recently installed a pair of smaller ones in the cockpit of my Mac26X, again with flush trimming and no visible (from the outside) hardware.
2,182
:dance:
Only thing to consider when trimming is whether rain does actually drain.
Dec 2, 1999
15,184
The originals were Gray ports (Pomponette). They sell them here on this website.
I would agree that trimming them flush or close to flush is best. They are very hard on the ankles.
