I was the one doing the maintenance so I know they have been cleaned & serviced using Lewmar specific grease and oil... Pawls have been replaced at least twice and springs every service. I just never realized or noticed how sloppy the pawl sockets had become...
When I serviced them last I did not replace the pawls as they appeared in good shape with square locking edges. The wear on the pawls is not as bad as the camera makes it look and the locking edges are still quite square especially when considering what type of meat they have to lock into.. I have seen way, way worse shape pawls, and the pawl sockets no worse for the wear.
Nothing else on these winches shows even the slightest wear, just the pawl sockets. I even measured the very edge thickness of a brand new pawl and one of the ones in the failed pawl gear. New one 3.95mm, old one 3.95mm. The round end 7.81mm new, old 7.81-7.82mm. So it appears the SS is not what gave up material..
I am not the only one to have seen this phenomenon and the Farr 40 class even has a tech sheet noting the upgraded SS pawl gears. The J105 site gives a part number for an upgraded hardened bronze gear for the guys over there who have had similar issue despite proper maintenance..
This was posted on the J105 forums by gbourne in regards to the same winches.
The entire thread can be seen here:
J105 Worn Pawl Gears
Below is an interesting read from the Farr 40 site and shows the "upgraded" parts and talks about why the hardened gears may be a better option with regards to "pawl pocket distortion" and better gear wear...
Farr 40 Upgrade Pawl Gear Parts (Scroll To Bottom)
"• UPGRADE
• Bronze Pawl Gears come as standard in the Lewmar Standard Alloy winches
• As permitted in the Farr 40 Class rules we are happy to offer the S/Steel
Pawl Gear upgrade.
• The benefits of this upgrade are a harder wearing gear package that will
handle the higher loads from the mast head kites. Reducing the Pawl pocket
distortion and the chance of back winding.
• Improving the efficiency of power transfer from input to output."
This may not be a common problem at all but it is easy to check and inspect and certainly beats a broken arm.... I am simply asking folks to check their pawl sockets as I clearly missed these getting so badly blown out.
