Help, can't find replacement for broken bleed screw
221
Catalina 310 USA
2001 Catalina 310, #112, m-25xpb
I broke the fuel bleed screw (the one on the injector housing) and cannot find a replacement. Toad marine (torresen marine) sent me one that is too big and cannot find a smaller one.
Any thoughts? I stopped by a kabota tractor dealer and they could not help me.
Any other online sources?
Hmm, I really, really, really want to know HOW you managed to do that.
Then I'll tell you the answer...:):):)
Naw, I'll fess up. It's a screw, right? If you have even a small part of it left, take it to a local machine shop and I'll bet they can give you a replacement.
Good luck.
PS - Please, how did you break it?
Oct 17, 2011
221
Catalina 310 USA
I had air (at least I thought I did, might not have been getting enough fuel either) in the system, engine was shacking violently and I had a socket on the bleed screw trying to bleed it......unscrewed it a little with the socket while engine shaking and "snap", it broke in half :cussing:
Oct 17, 2011
221
Catalina 310 USA
Crap, Universal says they are a good 6 weeks from seeing the 301749 bleed screw.
Back to square one. Anyone have thoughts on where to source one?
Dec 14, 2003
1,443
If you have the size and lenght you might try a motorcycle shop. Take yours and match the thread with what they have.
Oct 17, 2011
221
Catalina 310 USA
Update: I used a normal screw from lowes that fit. Ran the engine for an hour yesterday with no apperant issue. I will replace it once the bleed screw is off back order.
