Does anyone have any pictures of their transducer mounted in a wax ring?
I'd like to see some if possible so I have an idea how to do mine.
Thanks in advance.
Jibes, one reason I used plumbers putty rather than wax was the cleanup issue. I know that the Putty will withstand -30 degrees f and still hold. It has a number of times and has been in place for 3 years.This sounds like a good idea but I have a couple questions. Does the wax get really hard and brittle in freezing weather (like sub zero)? Do you get wax all over the place every time you access the area where it is applied? I epoxied a transducer directly to the inside of my hull once and it worked fine.
Around here during the summer we use hair driers to cool things downYou might want to try using a hair drier to soften the wax a bit before setting the transducer to ensure a good contact
Me too but my current boat has a through hull transducer. On my previous boats I made a circular dam out of masking tape, put the transducer in the void and filled it up with resin. I think I used the cheap ester resin (polyester from auto-zone). It cures nice and hard and no mess. No problems and I had a great signal. I also like the plumber's putty idea. I use plumber's putty for a lot of other things on my boats but never thought to do that with it. It is a good thing to have in your spare parts bucket. I use it for emergency leaks around windows, ports, hatches and keel pivot pins etc. Smash it in place... things stay dry until you can get back home and fix it right.... I epoxied a transducer directly to the inside of my hull once and it worked fine.
