My Kiwigrip trial
412
Catalina 27 Victoria BC
Before we head out on this summers extended cruise, the nonskid in our cockpit needed renewal. I'd looked at several options before settling on Kiwigrip.
I gave it a go today starting on a small area to get a feel for the product. If you've never used it, here are a few tips.
Despite it apparent thickness, I found it a bit runny. It's deceiving because I expected it to have a mayonnaise-like consistency, but I feels thinner than that. No big deal, but it will spatter off the roller.
I had purchased the special Kiwigrip roller with the product but while I was at the hardware store having it tinted, I spied some 3 in wide stucco rollers similar to the photo. These rollers have smaller loops so much less 'open'ness' to them. I thought they might produce the degree of grip-i-ness (sorry for the technical jargon) I was looking for.
I had heard horror stories of too much product causing challenges so I applied it with an 1/8" notch plastic spreader. Worked like a charm.
I found that I could actually use the small loop roller to apply the product to areas that I missed with the spreader. The texture created was exactly what I was looking for.
I applied it in the shade, the air temp was about 27 degrees C. No issues with lack of working time. I rolled it to the consistency I wanted and found the roller by itself produced the right texture.
I pulled the tape and the Kiwigrip dried to the touch in about 20 mins.
All in all, very impressed. I've included a side-by-side of old and new and a close up of the texture. Not happy with the new colour but that's easily fixed.
I highly recommend this product. I have no affiliation with the company, just like the stuff!
Likes: Sanctuary2
capta
Jun 4, 2009
5,103
What was your prep? How did you get it "roughed" up; I assume you didn't sand the old non-skid?
Likes: Sanctuary2
Jun 1, 2004
412
My prep was pretty simple. I washed the area with mild detergent and after it dried I wiped the area with acetone.
The larger part of the cockpit sole sees more foot traffic so feels smoother. I'll probably wash it, then a light scuff with some 220 grit, vacuum and wipe down again with plain water then a final wipe with acetone.
Likes: Sanctuary2
