Finally finished a set of doors - much more convenient when cruising
hello allFinally finished a set of doors - much more convenient when cruising![]()
Doors are simply easier to managed than the three slats, and provide more convenient access without having to remove.Jimm,
Nice job pal. I recall an earlier post on door vs. slats, maybe it was your thread.
You did mention these are great for cruising. So I assume the doors are removed and stored, but you do the same for the slats. I would think the doors by their shape, take up more room to sto than slats. Does the stationary hinge have the pin in it? I wonder if this may be a catching point for folks entering or exiting.
>>>>>>>>>> The two panels fit nicely under the quarter berth cushion, though under most conditions they are simply closed when sailing. Yes the pin remains in place, but does not extend out much and has not been an issue.
One thing I did notice in your pic was what I saw as potential leak areas by design.
I recently re-designed my slats to close the upper areas better off to stop rain getting in. This worked better however, every Catalina owner has problems with water leaking in because of the angled companionway design.
>>>>>>>>>> One trim piece that overlaps the middle seam has not been installed yet
. That plus the bimini/dodger system provided a water tight system.
Happy sailing pal, ya know what the say about sailing, just add water.
CR
