how to make safety line covers?
35
Macgregor 25 / 26s pugetsound
wondering what people are using to make those niffty safety line covers? Not sure what they are called. Usually white, look like they are soft maybe with a canvas sleeve ? I like'm
Ross
Jun 15, 2004
14,693
Do you mean the lifelines between the stanchions? I covered mine with three strand laid line that I opened and wrapped around the steel wire core.
Ross
Jun 15, 2004
14,693
After I laid the rope open and wrapped it around the wire core i hitched over it with # 80 seine twine and worked turksheads on the stanchion tops.
166
Nonsuch Ultra 30 Gulfport, FL
Hey Ross,
If you're ever in the St Pete area please stop by. How about dinner for you and your significant other to have my wheel done?
Ross
Jun 15, 2004
14,693
If you can tie half hitches you can do this. They even teach it to sailors. ;)
Apr 3, 2008
166
Ross,
OK I'll bite. Where can I get instructions? The invitation still stands regardless of your attempt at humor.
May 20, 2004
151
C&C 26 Ghost Lake, Alberta
The usual method is to use those foam " noodle" thingies that kids play in the pool with. Covered in Sunbrella with Velcro along the length and a pull cord at each end.
I'm pretty sure there is a free plan and/or video on the Sailrite site.
Sam :)
Jun 21, 2013
35
Sam :)
that would do it, the one's I've seen are to thick, but a thinner one would be perfect.....
Ross
Jun 15, 2004
14,693
Ideally you should be able to wrap your fingers completely around the safety grab. It should be solid enough to not crush under load and provide enough gripping surface that your hand won't slip and large enough as to not place point loading on your hand. Get 3 or 4 feet of 1/2 inch and 5/8 inch 3 strand and try it on the lifelines.
Mar 22, 2004
733
Hunter 30 Vero Beach
If you don't want to go as big as a noodle, you can use pipe insulation with the same type of cover that Sam Salter talked about. I made some for my last boat, and used some hose on the inside of the pipe insulation for extra rigidity. It's small enough to still be able to wrap your hand all the way around.
Ross
Jun 15, 2004
14,693
How do you accomodate a 5/8 inch hole in the insulation to the 1/4 inch wire rope?
Tom
73
Lancer 28 T Great Lakes
Looks really nice, but makes it pretty hard to check the condition of the life lines though. But damn, it looks great.
tom
s/v GAIA
Mar 22, 2004
733
That's where the hose comes in. The ones I made I used a thick walled plastic tubing. There was a little wiggle room, but not a lot.
