Water in bilge when on the hard
3
Hunter 25.5 Rocky Fork
I have water in the bilge when the boat is on the hard, but not when in the water with the mast up. Any ideas where it's coming from?
Tom L
Jun 24, 2004
56
Hunter 23.5 & 29.5 Baltimore, MD
The forward hatch on my 23.5 leaks when on the hard because the bow of the boat is tilted up higher and water pools at the hinge of the hatch instead of running forward and off the deck. (The gasket under the hatch has developed a gap back at the hinge and needs to be replaced.)
Apr 16, 2012
73
Hunter e33 Newport Yacht Club - Stoney Creek,ON
Friends of our who has a 2012 H33 had recently some repair done on the rub rail. During rain fall or washing the boat, water leaked into the boat by the aft cabin.
I also have water in my bilge and trying to locate the source.
Apr 17, 2011
3
Leak into aft cabin
I tightened the toe rails and that seemed to take care of the leak in the aft cabin of my H25.5
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
maybe you could check the anchor locker drain on the bow where it goes thru the hull.check the other thru hulls-drains/breathers. I know of situations where the anchor drain had cracked from age and when sailing at a good heel, it was scooping up seawater which eventually drained into the bilge.
another spot could be the base of the rear cage where it mounts to the coaming.
