I have my M25 up off the trailer and tried to lower the keel with the winch. No go the winch only goes one way - UP.
I plan on putting a jack on the aft part of the keel and taking the strain off the cable and seeing if I can find the winch lock lever to jam it unlocked, then try to carefully and slowly lower the rear of the keel by letting the jack down. The keel cable appears new but is held by 3 u bolts so I surmise the whole set up is a jury rig.
Any advice or info on this would be appreciated.
James
pic of winch does anyone recognize the type? the handle seems to turn without moving the drum when I try to go in the let down direction. I didn't move it much, thought I might be unscrewing it and would create a bigger problem.
James
