need source for clevis pin 5/32"x1/2"...
3,983
I have a ronstan 28mm swivel block and the shackle pin has been lost....
does anyone know of a source for these? it is a 5/32 x 1/2.... or 5/8" long
it seems that the 5/32" diameter pins are not common. thanks.
Mar 20, 2012
3,983
I could buy another shackle to replace it, but a pin should be a couple dollars vs 28 dollars for a new 28mm swivel becket block...
west marine doesnt offer 5/32 pins.
6 or 8 mm equates to 1/4 and 3/8".... 5/32" is smaller than 3/16 but bigger than 1/8"... a 4mm would probably work if i could find one.
Mar 20, 2012
3,983
thans for the replies... every supplier this side of the pond seems to have 1/8 and 3/16.... if i want 5/32 or 4mm, it seems I will have to order from the UK...
WADR, a 28 mm block seems to be more easily replaced in toto vs. trying to find an unavailable component. Try pricing a replacement block and you might find that, even if available, it may be more cost effective to replace the whole, then spend some time finding the right part and having a backup.
Good luck.
Beneteau 323 Annapolis MD
Did you consider getting the right size of a bolt, easier to find- even West has them i'm sure. Maybe even a lock nut while you're at it. Lots cheaper, i'm sure.
Feb 5, 2009
255
Gloucester 20 Kanawha River, Winfield, WV
I have a ronstan 28mm swivel block and the shackle pin has been lost.... does anyone know of a source for these?
Buying a whole shackle might be less wasteful than buying a whole block. Here's a long 5/32 shackle:
http://shop.sailboatowners.com/prod.php?14512/Long D-Shackle
Here's a standard one, but it's out of stock at the moment:
http://shop.sailboatowners.com/prod.php?14415/Standard D Shackles
And if you're really feeling adventurous:
http://search.ebay.com/search/search.dll?satitle=5/32+shackle
