Rebuild/replace sea water pump
5,836
Hunter 36 Punta Gorda
I think my sea water pump is leaking on my H-36 3YM30 Yanmar,where is best price for new pump or rebuild kit.
Nick
Dec 2, 1999
15,184
How old is the engine?
There is not much difference on new, but rebuilding makes sense.
Oct 29, 2005
2,366
Rebuilding is easy. You'll need new Oil seal. Depending on condition, you may need new shaft, Bearings, C-clips, and O-rings. After rebuild, you shouldn't tighten the CW Pump belt too much, infact leave alittle loose but not slipping. Too tight and the shaft will wear the oil seal one sided and will leak again soon enough.
Oct 29, 2005
2,366
I can send instruction on rebuilding cw pump. I've written after I've mine and couple of them for friends.
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
Yes it is not had to replace the rubber seals on pump. This I believe is the most common for seal to start leaking when to much belt tension is used.
Dec 19, 2006
5,836
Ken13559
I would like info in rebuilding the sea water pump mostly the seal and I sent you email or contact me here private message.
Nicck
Jun 25, 2012
942
Nicck
Here are some pictures of when I fixed mine. It shows the seal in question. The rubber "O" ring is what I used to help tighten the seal around the shaft. Inside the seal is a spring. I stretched the "O" ring over the spring. Made it good for a few more miles. I found a over priced replacement seal from the local Yanmar dealer. Have it saved for when I really need it. I have not done the speed seal plate yet but plan to when I get the bracket that will allow the pump to face the correct direction. Which should have been caught at the yanmar factory.
One of the pictures has a red oval around the location of seal that is were I bet is were your leak should be happening around the shaft.
The picture with the red box show were the seal gets pressed into place. Sorry I had already pulled the seal out before picture. But you will see it when you remove yours. Hint take...Take cell phone pictures as you go. You will find it is not that hard to fix, just basic skills needed.
Luck!
5,836
Seal
I will order a new seal for my pump from my local yanmar dealer in Ft Myers,does any one have the blow up photo of the pump.
Nick
Oct 29, 2005
2,366
Nick
I have the exploded view. Its from the parts list. I send you the page you. PM me your email and I will send the info you need.
