Noisy Pipes
1,087
Mainship Piliot 34 Punta Gorda
I must be getting air in my water lines because I am getting a vibration in the lines when the water is on. Where could I be getting air?
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
Maybe from your empty water tank?
Sorry couldn't help it.:D
On a more serious and hopefully helpful note. Is there air spitting out the Faucet? Check to see if you have a leak somewhere just before your water pump. Is your pump holding pressure in the line with all the faucets closed otherwise?
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Pump
How about the pump screen filter or a loose fitting or pin hole some place
Nick
Oct 26, 2005
2,057
- - Satellite Beach, FL.
Yep, between the tank and the pump, otherwise you'd have a water leak and the pump would be cycling.
RichH
Feb 14, 2005
4,773
Bleed air from your hot water heater - First. Simply pressurize the water system then open the 'pressure relief valve' on the hot water heater until all air is expelled .... as a FIRST step before investigating for loose or leaking water lines.
Dec 19, 2006
5,836
Wondering
I was wondering how you made out with a new linear drive for your auto,I am thinking about adding below deck # 1 linear drive for my auto and maybe you can offer advice or pros and ccons.
Nick
Jun 4, 2004
1,087
Nick
I have a rotary drive Nick. I replaced it and it is working fine. Why it failed is the question.
