Removable Key On/Off Battery Switch
Here's one I found that is white. The bottom of the switch panel is exposed however. Many are like this though...dimensions say 5.25" x 5.25" x3". Pretty big.
Nrmlspeed... I found the
Hella: Removable Key On/Off Battery Switch the better deal and easier to install. Plus the cheapest...If there is a better or cheaper brand then I am not a where.
I mounted one a long time ago in the cockpit...
"MOUNTING" All it required was one hole drilled. And a small amount of black caulking around the hole. There are no screw heads visible. How did I do this ? I used a small amount of 3m5200 to glue a small wood block to the back side of the mounting location. Once glue was set I drilled the appropriate size hole. Placed switch into bulkhead hole from the back side and used two just long enough s.s.wood screws into the back side of switch see picture of switch, it already has the holes in switch. Next squeezed in some of the black caulk and then wiped away the excess. Waited for caulking to set. Then connected my cables. Enjoy!
The removable red key switch can be stored below ..... which keeps some kid from messing with the switch and turning it on . It is mounted nearly flush and is barely noticeable. In fact no one but me knows what it is unless I tell them. Just be sure in your case to mount it, if you can were when its in use that the key will not get stepped on and broken it off. Mine is not mounted that way... but the key has only been used and left in the hole slot for a minute or two at a time. I have mine placed were I will not forget about it.
Will try to keep the rest of my ramblings simple if I can....
I first used it as a simple quick way to combine start battery to house bank without having to run below. This was when I was having trouble with the factory defective yanmar wiring harness back then. The defective yanmar harness issue has
"FINALLY" been solved !! The cut off switch is still there...It was mounted in a convenient location already so I now only used it as a way to combine main engine start/reserve to the generators dedicated and otherwise separate gen start only battery. I have yet found the need to use it for that purpose. Been thinking of just switching it around to use it as a cut off for the generator battery. Luckily this would not be hard to do because both generator and engine reserve/start batteries are only about 3 feet away.
