I just bought a 1982 Catalina 30' tall rig. She was a salvge boat from Superstorm Sandy though the damage is minimal.
There are two small puncture-type holes below the waterline that did not hole through. They are easily repairable.
The bow pulpit is damaged and needs to be replaced.
The biggest issue I see is that the keel obviously hit something hard and exposed a horizontal crack in the glass around the front of the keel. The crack is about ten inches below the hull. There is water slowly dripping down the outside of the keel from the bilge. My question, or questions...
Is this where the keel to hull joint is, 10 or so inches below the hull and not where the keel and hull meet?
The keel bolts look solid though I haven't put a wrench on 'em yet. The boat is at a sailboat marina with skilled craftsmen and I'm pretty handy too.
Do you think simply dropping and rebedding (and then reglassing) the keel is the solution?
Any input would be helpful.
