Changing the exhaust hose on Hunter 31 with a Yanmar engine
320
-Irwin -Citation 40 Wilmington, NC
Re: Changing the exhaust hose on Hunter 31 with a Yanmar eng
Nope. But I would not leave the hose off overnight or the boat unattended without putting something in the hole. Piece of cake, just like wrestling a python in a phone booth laying on it side :)
Capt. Wayne Canning, AMS
www.projectboatzen.com
Dec 2, 1999
15,184
I never changed mine on our H31, but it is a SOB. The hose is stiff and it needs to be fed from the muffler, though that pan, under the aft berth and back onto the engine. I think you want to replicate that loop from the muffler box to prevent water from getting back to the engine.
I would think that some of that slime stuff that the electrician use to feed wires through a conduit would come in handy.
I would figure a few hours to do the job and it will probably take two people.
Apr 19, 2011
456
Hunter 31 Seattle
we did it by running a half inch guide line (old price of dock line) through the hard parts then pushed hose over the line and it followed the bends of the line. I haven't been able to replace the second piece that goes to the through hull but it didn't look like it was in bad shape either....the first piece takes all the abuse it looks like
I agree with Steve. We did ours earlier this year. 17 feet. The old hose was cracked and was leaking fumes. It is a good thing to replace. Took my son and me three hours, although i spent an hour the prior day getting the hose off the thru hull. If you're in a protected environment, you can leave it off, if you have waves or bad weather, seal the exhaust hole up first.
It is really worth doing.
Apr 3, 2013
11
Hunter 31 Portland
Wow, thank you all for the very fast replies. Guess I'll go buy 20 feet of hose. What size hose is it. I guess I can take the old one off to find out.
I'm in a very protected marina. But I think. I'll still cover the hole.
Thanks again......Jim
Compass Rose II
Dec 2, 1999
15,184
Jim: I think the hose has an ID on it so you should be able to determine the size. Too many years ago to remember.
Jan 4, 2006
7,783
Cut a piece of hose off to take as a sample to your supplier. Be sure to jam a plug into the hose and clamp it before you leave the boat. Ya just never know and just think of the embarassment if you came back and ......................... :eek:
A hair dryer on the hose works wonders when removing and installing the hose on fittings. Your wife shouldn't mind.
Oct 29, 2005
2,366
Wrestling a python in a phone booth? Very interesting and accurate description. Hahaha.
