Sortir le moteur de mon Catalina 30
8
Catalina 30 Rimouski
Bonjour ! La saison s'en vient à grands pas ici à Rimouski au Québec. J'ai fait entièrement refaire mon YSM 12 d'origine (1979) de mon Catalina 30. (5000$...) Mais il est comme neuf et redonnera une nouvelle vie à mon bateau, tout en le conservant d'origine. Voici ma question: Puis-je le remettre en place à l'aide de ma baume ? Est-ce que je risque de l'endommager ?
Merci
Orizon
According to Google translation: "Hello! The season is coming fast here in Rimouski, Quebec. I did completely redo my original YSM 12 (1979) my Catalina 30. ($ 5000 ...) But it is as new and restore new life to my boat, while still retaining the original. Here is my question: Can I replace it with my balm? Is there a risk of damage?"
May 27, 2012
1,152
Oday 222 Beaver Lake, Arkansas
I think he's asking if he can use the boom to lower the engine into the boat? Funny, I was wondering if i could raise my outboard with the boom on my 222.
Jun 1, 2004
8,267
For a $5000 investment.... I'm renting a cherry picker, or a front end loader.... or something like it.
dj2210
Feb 4, 2012
337
Catalina 30 Watts Bar
There is a video on the web somewhere showing an A4 being removed with the boom from a C27. If going that route I would use the main halyard attached at the boom near the pick point to take the load and not rely on the topping lift.
Mar 11, 2010
292
Catalina Tall Rig/ Fin Keel Deale, MD
I found an engine manual for this engine:
http://www.ship468.org/boats/Catalina30/YSM12/Chapter1 - General.pdf
At a dry engine weight of 130-120kg (286-264lbs), the boom (supported by the topping lift on the end and the main halyard strapped at mid-point) should be easily sufficient to lift the engine.
If the boat is on land, make sure the hull is well supported on the side you're lifting. Perhaps add an extra boat stand near the lift point?
Rob
jrowan
Mar 5, 2011
1,294
Oui, vous pouvez aussi j'ai cru que vous avez demandé, augmenter votre moteur avec votre flèche. Assurez-vous d'utiliser la drisse de grand voile et la balancine via les treuils de mât pour augmenter votre moteur, en utilisant une seule personne sensibilisation sur chaque treuil. Si vous ne pouvez pas serrer contre votre balancine puis utilisez votre drisse de foc pour soulever le moteur. La YSM 12 est un moteur plus léger, pesant environ 300 livres, donc il n'est pas trop lourd pour la flèche. Bien que vous devrez fournir pour faire glisser le moteur à l'arrêt du moteur se monte à ouvrir la voie écoutille principale. Heureusement, notre trappe 30 C est si grand que vous conduisez un camion à travers elle. Bonne chance et que vous regardez de retour de blessure.
Cheers, Jeremy Rowan, rowan1930@comcast.net
Merci
Orizon
Nov 4, 2012
8
Thank you so much for your advices !
Merci de vos conseils !
Paul
dj2210
Feb 4, 2012
337
JR LOL he probably meant internet translators.
This is what goggle translator turned into..
"Yes, you can I thought you asked, increase your engine with your arrow. Make sure you use the main halyard and topping lift winches via mast to increase your engine, using one person on each winch awareness. If you can not tighten against your topping then use your jib halyard to lift the engine. The YSM 12 is a lighter engine, weighing about 300 pounds, so it is not too heavy for the arrow. Although you will provide to drag the engine off the motor mounts to pave the way main hatch. Fortunately, our trap 30 C is so great that you drive a truck through it. Good luck and you look back from injury."
May 27, 2012
1,152
Just what do you mean by that? At least I gave him a response in French.
No, I wasnt referring to what you wrote, I think the main point came across, but certain words, like boom, come out different. He originally said baume, which it turns to balm. It was only by googling baume that I found beam. Going the other way, boom comes out something else. Then too I wonder if Quebec french is different from the old country, etc., local culture terminology. I just meant the translator programs arent 100% right.
I dont speak french, so must (for the time) rely on these translators. But I do not as yet feel comfortable they are that trustworthy. I would hate to have something come out the wrong way, wars have started over stuff like that, lol.
Nov 4, 2012
8
French/english
Anyways guys, i understood every word you wrote me! We speak the two languages in Québec !
Thanks again !
Paul
May 27, 2012
1,152
Cool. Maybe soon we'll have a translator app on our smart phone with voice recognition, lol
I was going to just say that you could tie all your halyards to the boom at the lift point to take the weight, or even spread them some. Just watch that the lines dont stretch and the boom starts bending.
Feb 8, 2011
45
Beneteau 361 Grand Bend
Oui,
I replaced a westerbeke mxp 25 with an mxpb25 using the boom. Lots of room. 6 guys from the club picked it up from the back of my truck using 4x4's run through the pallet, carried it onto the dock right beside the boat. From there we created a purchase by attaching a block to the lifting ring on the engine. It was a few years ago but I think we ran the main halyard to the block on the engine, then up to a block on the boom, and back to the attachment point on the engine. We also tied off the topping lift and the spin halyard on the boom close to the lifting point. By creating the purchase and having some friends guide the engine itself I don't think we even had to use a winch. By repositioning the block on the boom it was easy to move it in through the hatch once the engine was on the boat.
This ended up being the easiest part of the entire replacement.
Il etais beaucoup des ans depuis je parle francais mais si vous souhaite 'email me off list' pour mon nombre et je vais essayer en francais
Randy
