question about water depth around queen mary
175
1974 Macgregor 22 SoCal - dry storage
so i'm looking at the noaa chart around queen mary, am i reading it right? some of the water depth is only 3 or 5 feet? see circled number of attached pic.
ps, map is 18751_1
thanks
Jun 1, 2004
8,205
ps, map is 18751_1
thanks
On my map that shoal is marked....... but hey... now you know where not to go.
Nor is the QM planning to go anywhere...:) And isn't that shallow water further INland?
Jul 20, 2011
175
well, I'm planning to go thru that channel to get to one of the the marinas in there. I guess I'd better stay way to the other side.
Catalina 310 278 Lyndeborough NH
The Queen Mary retired to her present location in 1967. The water in today's charts show low tide depths of 30+ feet. She would have come in from the EAST - the deep water side of your map. The Queen Mary's draft is 39 feet. She is now contained within her own protected "pond".
I suspect that the water depth was quite adequate when she was brought to the site at high tide and with the Queen Mary lightened without passengers and large loads of fuel.
caguy
Sep 22, 2006
4,004
You can't get that close anyway without the CG chasing you off. The water can be that shallow further up stream. There is a trench that the Catalina Express uses on the other side of the river. The water is also deeper along the west bank going up to the landing. The center is pretty shallow. I tried to cross it my first time to get over to the Catalina Express trench but got stuck in mud half way. Fortunately the Mac 25 has a retractable keel so getting unstuck was easy. The water is so nasty there even in two feet of water you can't see bottom.
Nov 8, 2010
11,386
Surely you meant WEST.
Dec 2, 1999
15,184
Ask Rick Dinon. The stern of his boat matches upwith the sternof the Queen Mary.
Rick D
Jun 14, 2008
7,186
That's Correct re: Shoal
so i'm looking at the noaa chart around queen mary, am i reading it right? some of the water depth is only 3 or 5 feet? thanks
Correct, and I think there are some areas silted up even worse since those soundings. Whenever I see some sails full but stationary, I know what's happened. yes, the channel is marked. Stay to the northern side of the marked channel and all will be good. BTW, good for you for checking!
Dec 26, 2012
359
MacGregor 25 San Diego
That explains why all the channel markers are way over to the other side. I was just there a few weeks ago, and it is indeed very well marked.
Jun 1, 2004
8,205
You have a flair for the obvious, my friend.
