Difference between 1977 and 1978 oday 20
69
Oday 20 My garage
Hello all,
I have a 1977 oday 20 and it currently has a 26.5' hobie 16 mast and sails. It has been retrofitted with spreaders and re rigged properly. I am curious if there is any difference between the 1977 and 78 aside from the fractional vs masthead. I know the mast is about 22' on the 78 and 27' on the 77. I guess my main question is would there be a problem with getting a mast from a 1978 and putting it on my boat.
Thanks,
Scott
Aug 24, 2012
16
O'day 20, Barnett Butterfly Clinton Lake
Hey, I too have a 1977 O'day with a Hobie 16 mast on it! Just brought it home a few weeks ago. What a small world.
What kind of mast step do you have? Did you retrofit the Hobie 16 mast yourself? My mast does not have spreaders and needs a proper mast step, but I've been having a hard time finding a tabernacle or hinge that will work. I'd love to learn more about your rigging. I haven't even had my mast up yet! I've been looking to replace my mast too, but it seems more financially reasonable to just sail it.
As far as the difference between the fractional and masthead rig, I do know the shroud plates are set further aft of the mast on the fractional than on the masthead rig. The Fractional also had a longer 9' boom; the masthead had a roughly 8' boom. And if you have Fractional sails then they won't fit the masthead rig.
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Hey guys,
I really don't know too much about the O'Day 20. One of our past YC members owned one years ago. I never had the opportunity to really check it out that close.
With that said, a 27' mast seems to be too long for a 20' keel/centerboard sloop. A higher mast means more sail area and unless the boat has a full keel, I would stick with the shorter version. My 1986 O'Day 222 keel/centerboard has a 27' mast and my keel weighs 800 lbs.
I'm not sure if you guys can find a mast plug or casting that will fit in your mast in order to mount a stainless steel Dwyer hinged tabernacle. It really depends on what is available out there from the spar manufacturer. My mast was built by Z-Spar and I couldn't find a mast plug for it a couple of years ago,- but ya know what? I made one. It works great. You can do the same thing I did if you can't find a casting that will fit in your mast. The casting or mast plug is held in place with screws going into the side of the mast. I used four long stainless steel bolts to attach the hinge plate to the plug. I originally started out with two bolts and added two more. You can read about it in my picture album.
http://forums.oday.sailboatowners.com/album.php?albumid=372&page=3
Years ago when I replaced my mast, the rigger told me to mount the tabernacle on a 1'' Teak board on the cabin to make up the difference between my old tabernacle and my new on in relation to some of my existing stays. I replaced the Teak board with a piece of 1" thick Trex about a year ago and used Butyl Tape to caulk it.
The reason I mention this is because,-- that 1" height allows my mast to lay a lot lower in my rear mast crutch when I'm getting ready to raise my mast with my Gin Pole. I really never took advantage of this until I started using a Gin Pole to raise and lower my mast. Naturally, if you're raising a mast on your boat by hand, you want to set the crutch as high as possible. With a Gin Pole in use, the mast can be laying horizontal and go up nice and easy with a set of blocks or a small boat winch mounted on the Gin Pole. The Gin Pole provides the angle needed to lift the mast.
If you need to cut your mast you can cut it with an ordinary crosscut power saw with a carbide blade like I did. This is what they generally use in rigging shops and spar manufacturers also use them. Just make sure you get a straight cut.
Good Luck guys!
Aug 8, 2012
69
Oday 20 My garage
Joe thank you very much for your input. As to the length of the mast I have confirmed with a gentleman in florida the height. He did a full restore on an 1977 o'day 20 just like mine and it has the 27' mast. Additionally the data on sailboat data for a o'day 20 fr concurs. Possibly this is why they changed the dimensions down to a 22' for the reasons stated by Joe.
rwilliams,
I would love to help you out with your oday. I purchased mine about a year ago and was very discouraged in the beginning. I have done enough research on this whole topic to make most people sick in the head and now my reasons for wanting a new original mast is just so I'm not flying yellow and white sails :). Send me a quick email scott.stevenson07@gmail.com and I will reply with my story of "Harper" and what I did. The short version is that the total sail area between a hobie 16 and our 1977 oday is only about a 10sq ft difference, more for the hobie. From a sail maker I talked to he said, "us racers always want more sail ares." Now I am not a racer, so you just have to be heads up and let out your sheet if you start to get over powered. The other aspect is that the mast is built a bit differently which doesn't provide as much lateral support. The only time this will come into play is if I were sailing it in significant wind in the Bay. I live near SF. That info came from the leading sailboat shop guy in my area. I'm guessing 30+ years of sailing. Anyways shoot me a quick email and I'll send you photos and help you out. It's definitely been a journey and many have helped me, I'd love to pass on what i've learned.
Aug 24, 2012
16
I love the idea of using the 'Trex' material, and how you built up the base. Is there any reason you used the PVC trim boards under the aluminum instead of more Trex?
Aug 8, 2012
69
Oday 20 My garage
Joe,
Do you also use trex for your handrails and hatch channel boards? I'm thinking of doing this and want your opinion on look and functionality as well as projected durability.
Scott
Jan 24, 2005
4,881
Yes. The PVC Trim board isn't exactly 1" thick and I needed exactly 2" and wound up having to make up the difference by cutting the PVC and gluing it with PVC cement which you can't do with Trex.
Also, PVC Trim board can be spray painted with Krylon. I don't think Trex can be glued or painted.
The PVC board is lighter in weight than the Trex. When I first Mickey Moused my mast extrusion using just the Trex to get me by for the rest of the sailing season, it worked OK but it looked fugly and it was very heavy at the end of my mast when I trailered my boat to the club that year. However, it got me by for the season.
This newer mast extrusion is lighter in weight, it looks presentable, and it works. The weight of the mast is sitting on a 1/4'' Aluminum plate and the stainless steel bolts and screws are insulated from the Aluminum with Never-Seize. I also used nylon washers for the SS screws going through the mast.
Jan 24, 2005
4,881
Joe,
Scott
I haven't as of yet used Trex for anything else other than the mast extrusion plug and the mast step.
Personally, I think that Trex would work out great for handrails, hatch slider moldings, and toe rails. It may be a little too heavy for companionway hatch boards though.
Some guys are making them out of StarBoard. I need to replace mine and I haven't really decided on what to use as of yet.
Right now I have a medical problem that needs addressing and I've decided to put my mods on the back burner for a while and play it by ear.
Just recently, one of the guys on the forum "Merlinuxo" used Azek to make hand rails for his boat and they came out looking great. Here's the link. http://www.azek.com/azek-deck/colors/
Ahoy Merlin!
Maybe you can chime in on this one!
Jun 2, 2004
1,952
Oday Day Sailer Wareham, MA
Virtualy no difference in rigging between 1977 and 1978 O'DAY 20. Ditto for the 22, HOWEVER.... the 1979 model was the last year for the masthead rig 22 and 1980 was the first model year for the fractional rig 22. 1979 22 was first year for the K/CB version of the 22 (1'3"/4'3" draft instead of the original 1'11" fixed keel).
O'DAY 20 rig was changed for 1976 model. The 1973 to 1975 models had the masthead rig, 1976-78 models had hte fractional rig. The interior layout was also updated for 1976, going from the original layout that pretty closely matched the interior of the 22 with a bulkhead between the V-Berth and the main cabin to the more open layout of a pair of galley counters with space between for the head.
1978 was the last year for the 20.
Joe, 27' is not unusual for the length of the mast on a 20' boat. the CAL 20 and the CAL 21 both had a 26' mast.
4,881
As always, I stand corrected. Thanks Rod.
Jun 2, 2004
1,952
No matter what, if I have a 222 question..... I'll always go to Joe!
(and I guess, he always comes to me with Day Sailer II questions?)
Jan 24, 2005
4,881
Thanks guys. I'll try to keep my thinking cap on. I only wish that my guitar picking was as good as some of my sailboat mod ideas. :D
Oct 26, 2005
2,057
- - Satellite Beach, FL.
Ahoy Merlin!
I must have heard the shout Joe!
I'm happy with the Azek. The only drawback some might have with it is that it is a PVC dense foam so the cuts aren't real smooth. I recently came across a new one, "Endeck" that looks good and is also 100% PVC but unlike Azek has wood grain on both sides. I'd suggest that anyone thinking about using any of the synthethic lumbers check out the samples first. They should be available at any lumber yard that sells the product.
I still need to make new companionway boards and am thinking of frames out of Azek and centers of plexi glass. All the rest of my woodwork, except the tiller, is Azek (no rot, no varnishing:D and about 10-15% of what teak would cost in materials:D).
There are some pics on my "work on Cygne" album.
Jan 24, 2005
4,881
Ahoy there, Merlin,
A guy in the Carolinas told me about Trex and he said that you can apply heat to the sawed portion of this material and it will smooth right out. I really don't know. I've never tried it but it's worth experimenting with. If it works with Trex or Azek, it will probably work with PVC trim board. Of course, you'd probably want to do this outside or do it in a well ventilated area with a canister type respirator mask on.
Oct 26, 2005
2,057
Thanks Joe, I'll try it.
I do all this stuff outside. Problem right now would be too much ventilation!
Jan 24, 2005
4,881
My friend Wayne used StarBoard to construct his hand rails and the stuff split on him at the screw holes. He then made up a new rail and used cup washers for the screws. So far it's been working. The StarBoard doesn't seem to be as strong as Trex or Azek. It's a very light weight material too.
Aug 24, 2012
16
Okay experts, can you tell what year an O'day 20 was based solely on the sail number?
I'm trying to find out what year sail number '621' was.
My '20 is a 1976 (thought it was a '77 but I checked again) and I'm #922
so I figure 300 boats earlier has to put it in '74 or '75? Prior to the fractional rig being introduced? I'm just guessing though.
I know the Mariner class has a table of years and sail number ranges, but I've never seen one for the '20.
Thanks guys.
