Quick Question- Hurth tranny
I have to slide my prop shaft out of the coupling about an inch or two so I can remove an old and install a new SureSeal lip seal for my formerly dripless shaft seal.
Will removing the set screws on the coupling suffice or do I need to remove the entire coupling? The Hurth and Universal manuals are silent about this and I don't want to disassemble something that doesn't need to be.
Below is a pic.....and yes...I will be cleaning up the shaft and coupling!! It's on the list when I slide the shaft out so I have a little more access!!
