Hi guys,
I have an '82 H27 ( that's draining my wallet faster than a Senate budget fix) , that I'm installing a 2 battery system, using the BleSea Systems "add a battery kit" with an isolator and automated switch. I'm also installing a "smart" charging system.
I have a decent background in 12V systems, and have also done some research; but I have a few questions:
1: Because of budget retraints, I'm going to have to go "wet cell" this season, and convert to AGM's next year. The factory location for the current wet cell battery is under the aft quarter berth, about 2 feet from the house panel. It seems to have virtually no ventilation. Due to space restraints; about all I can manage in ventilation is a few "locker vents", in the 2 to 4 inch range, with one mounted at the base of the compartment in the interior, and the other "higher up" , next to the steps; which would put it just about even with the battery tops. In your experience, is that enough? in both cases, it would vent into the cabin, but I have a nicro vent drawing from the main salon, and another forcing air into the V berth. I'm not as worried about overcharging, but here in NC in the Summer, interior temps may reach triple digits on a few occasions. AND DOES ANYBODY HAVE A SOURCE FOR SMALL ROUND TEAK VENTS??!?
2: The current system has the feed from the battery running into the engine compartment, and the ignition panel ( Yanmar inboard) is fed through the "DC main" switch on the panel. In order to truly isolate the "house" power from the "starter power", how and where should I reroute those feeds currently feeding the ignition system off the DC main? The Bluesea manual ( and others), only address the "main" battery cables; showing attaching them to the new switch to isolate the engine system. However, the hot line to the ignition system needs to be routed somewhere, or else I'll end up either "A" feeding the house system from both batteries, or "B" relying on the house battery to feed the ignition panel as well...
Does this even make sense?
Thanks in advance-
Jim
2:
Thanks in advance-
Jim
2:
