Installation angle limits??????
6,244
S2 9.2a Fairhope Al
OK here is the conditions.......
1 replaced the new prop shaft strut
2 used a new prop shaft
3 used a new stuffing box spud
4 installed a yanmar 2gm20f
i installed the new stuffing box fully packed on a new prop shaft through the existing stern tube on my 9.2a s2 and it was center to the tube....then i set the strut to the hull aliening the cutlass bearing as i shimmed the strut to the hull and made sure the shaft was center in the Stearn tube.....there is 1/8 inch clearance all around the shaft inside the tube.....the cutlass bearing is centered on the shaft with equal pressure between the rubber and the shaft ...secured the prop shaft strut to the hull checking clearances as i went ...all are still good and sound.....went on to installing the yanmar 2gm20f on the bead rails .....when all that was done i ended up with a very high sitting engine in the engine bay ...so i checked the angle of the prop shaft relation to the level line of the hull i checked 16.5 degrees on a starrett angle protractor that seems to me to be too much angle.... i have the flanges with in 3 thousand's of an inch at this time between the shaft and the clutch ...... i had to add a lot of timber on the bed rails to get to where i am as of now .....
so i am thinking i have done some thing wrong here and am wondering what my options are.........obtw the original engine was a yanmar 2qm15
any suggestions on how i can back track this and maybe find my mistake if i have one........i don't think that little engine will perform well at this angle....
regards
woody
BobT
Sep 29, 2008
239
Gulfstar 37 North East River, Chesapeake Bay
Is your new strut a different length from the old one?
Did you raise the motor mount supports evenly fore and aft?
What's the angle of the old motor mount bed rails?
Is there a reference drawing of the two engines to compare offset between mount & output shaft?
Is the transmission different?
Maybe it's daylight slaving time messing with us yet again.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Is your new strut a different length from the old one? 1/2 inch longer
Did you raise the motor mount supports evenly fore and aft? yes by 1 and 1/4 inches
What's the angle of the old motor mount bed rails? i will check that tomorrow
Is there a reference drawing of the two engines to compare offset between mount & output shaft? yes i will check that also
Is the transmission different? will check that too
thanks for the reply keep them comming.....
regards
woody
Oct 2, 2006
1,517
Jboat J24 commack
Well they mostly do a REALLY bad job at the factory as it takes a LONG time to do it right
When my stern tube failed and I replaced it was pretty clear any semblance of aliment was by accident
If i had not used and aliment shaft to set the strut up correctly it would have never been any good
The strut was off abot .090 which does not sound like much BUT it changes the height of the motor 1 INCH at the front of it
Beneteau 323 Annapolis MD
Well, considering the engine angle off horizontal when the boat pitches into waves....
Sep 5, 2007
689
MacGregor 26X Rochester
The Yanmar manual says 8 deg. is ideal, and 15 is the max. The only way to change the engine angle that I can see is to change the angle of the shaft, being that it uses a rigid coupling. Where that leaves you, I couldn't begin to guess.
Jan 6, 2010
1,519
Wood,
When I installed my Universal M320A, I had to make brackets for the engine alignment off my stringers.
I made a drawing looking at the engine from the side view. I then made brackets based on the drawing. Look at the attachments to give you a better idea for reference.
I made the weldment drawings and had them fabricated from stainless steel plate. Your situation will decide the correct design for you.
Maybe the brackets are a better way to go to get the angle you want.
Good luck......
CR
1,637
Some engine manufacturers, including Yanmar, offer a gearbox with the output shaft at a downward angle so that the engine is level in the boat.
Any chance the old engine was like this? If so could the gearboxes be exchanged?
Also the angle you need to know is, with the rubber stuffing box support tube removed, measure from the centre of the inboard end of the log tube to the centre of the cutless bearing. Everything else follows from the line between these two points and, short of installing an angled gearbox or a universal joint, the position of the engine is already decided and there is little else one can do.
Jan 6, 2010
1,519
Or,
Run your shaft thru the cutlass bearing and put the coupling flange on the end.
Push it up close to the engine flange and see what the difference is.
Maybe you can adjust the engine mounts to get the angle you want.
One good thing is the matching circular keyway built into the flange faces. If you can get your flanges to EASILY slip together, you might have it.
Do a temporary fit-up and then check the shaft at the cutlass bearing to see it's not cocked out. It's trial & error until it's right.
CR
Dec 30, 2009
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
engine bed work
Wood, with my repower I had similar problems, the width of the engine mounts was ok, the stringers in my bed were 2 different heights, the old Renault engine rear mounts were like 4 inches lower I had to get them all to the same height, and as it turned out I had to rip approx 2" of height off both of them. This was not fun as they were about 4" wide and almost 4' long, laying sideways upside down trying to get push on a sawzall. This is where the plywood engine template with the motormounts attached and front and rear shaft positions that held a 1"metal conduit mock shaft at the exact angle and placement in relation to the engine. My engine supplier gave me dimensions for this, off the tech sheet prints.sounds like you may have to maybe make wedges for stringers to alter the angle?? Maybe step cut the stringers to get correct angle?? Make sure u leave enough room for your oil pan if you alter stringers, I ordered what they called shallow sump oil pan...Remember if your finish stringers are off make sure u err on the low side, u can always shim up, then glass...I really enjoyed the entire experience, you are at a critical stage, take your time and get it right, any questions I will be happy to help you out if I can, happy motoring...Red
6,244
S2 9.2a Fairhope Al
thanks for the replies...keep them coming......i have determined today that all the work of putting the strut to the hull and aliening the shaft to the Stearn tube are good at this time but i still have to check the boat one more time to see if it is indeed level with in 1/4 of an inch bow to Stearn as that is where i set it when i landed it on the hard.....
my problem with the engine is not that it is too high.... i can live with that..but that it is setting at 16.5 degrees when hooked up the the flanges of the clutch and the shaft ..... yanmar says no more than 15 degrees and that puts me 1.5 degrees over there recommendation so i am thinking i have to either live with it or raise the shaft strut up 1/4 of an inch to get with in 15 degrees and that will make the prop shaft tight on the top in the tube about 1/16 of an inch clearance and 3/16 inch on the bottom.....
not sure what to do yet i have to think about this hard and make up my mind if this will be ok.....i just don't want to have to haul the boat and deal with it after i splash.....i guess worse has been done .......the other thing i can do is cut out the Stearn tube and set a new one on a better angle but that seems to me a lot of work for 1.5 degrees ...and if this engine will run OK at 16.5 degrees i will just let it be what it is.....i only change engines so i would have a close cooling system and about 2 more horse power and the fact that this engine is newer that the QM model and easier to find parts for......if you see anything i have missed plz tell me as i like to have as many options as possible.........
again thinks for the replies so far........
regards
woody
Dec 30, 2009
680
I think they make a couple of different trans offset angles. I originally shopped Yanmar, beta and volvo, and I seem to remember 7 and 15 degree offsets on trans. Red
Oct 2, 2006
1,517
Jboat J24 commack
Its good to see somebody else use a dummy motor :)
As i said before IMHP most OEM jobs are marginal at best
IN having to change Seafevers sterntube because of shaft rub the first that that became apparent besides the horrible angle worn into the cutlass bearing was there was NO WAY it was ever right
It was not even remotely imposable to pass a shaft through a set of alignment bushings placed in the sterntube and strut
It may seem overkill but the blisters inside the tube and shaft run has dam near sunk the boat and there was some kind of bad marine-tex job between the boat and sinking
I have to do alignments on machines all the time so a dummy A4 motor was as simple for me as picking out some of my stuff that would sit 3.5 inches high on the engine bed
You have to love Cal and all fiberglass engine bed in 1970
I come form a mindset that your doing a WAG if there is a rubber part like a cutlass in place and always use bronze bushings as it does not allow any cheating
After wasting far more time than the repair took trying to NOT do the repair i now have a sterntube and strut that are in as perfect alignment as it gets
You can walk right up to my boat and turn everything with ONE finger and look at a shaft going dead straight into the tube
FWIW my homemade pilot-drill and the big azz hole i had to make
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
correction
correction on my answer they are the same strut as it came from the original manufacture...they checked out the same...
and after correcting the answer i gave you last night i think maybe i see my problem...i had to shim the strut down about 3/8 to 7/16 of an inch to make the shaft center in the stern tube...so haveing said that i may have to go back and raise the strut thighter to the hull and even drill out the old stern tube and install a new one:eek:.....oh well better now than later in the water......
regards
woody
Woody, there are two "parts" to the new strut: it's length and the angle of the shaft into the strut, right? If they are different than your old one, you are going to get something different inside. If either of these was different, then I can't imagine how you got anything lined up at all. I think you're on the right track. Good luck with your alignment.
Oct 2, 2006
1,517
Jboat J24 commack
Woody
Remember what i said .090 or about 3/32 at the strut will change a motors height about 1 INCH
The .090 X the 6 some odd feet to the front of the motor is a big deal
I had to put wax paper on the hull and mold a fiber reinforced epoxy shim between the hull and strut
This allowed the strut to then be bedded in compound and tightened correctly with silicon bronze hardware
May 21, 2009
362
Hunter 30 Smithfield, VA
regards
woody
I think you've found the problem. Shimming the strut down increases the angle between the shaft and the hull, and drives the other end (engine) higher. I'm not convinced you have a problem with centering the shaft in the stern tube. Think of the stern tube as the pivot point - strut goes up, shaft still centered in stern tube, engine goes down. Your thoughts?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Woody
thanks tommays for the info it is good advice....
regards
woody
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
i agree totally with that scenario
regards
woody
