I have access to a Lewmar V7oo windlass with a gypsy that takes 1/4 in chain and rope what are the opinions of this windlass for my Catalina noting that nearly all anchoring will be in reasonably good weather
Sorry can't post a picture boat is 800 miles away but locker is not so deep so I will have to mount on deck and it has a split hatch down the middle. Really looking to see if this windlass with 1/4 in chain is big enoughI can't exactly remember what the anchor locker on that version of the C30 is like, but I think something like this from Cruising Outpost would work.
Maybe it would help if you posted a photo of what your anchor locker looks like now.
Good luck,
Jesse
This would all be part of recomendations as I want to replace everything ..thank youSorry. Misread your OP.
What size anchor and how much chain are you going to use?
Wiil not fit in chain locker and I have a way to mount the V700 really just need to know if 1/4 chain and this windlass is big enough for a 25 lb anchor and 30 ft 1/4 chainA good general rule is the weight of the anchor and ground tackle when fully deployed should not exceed 30% of the maximum rated pull of the windlass. The issue I see with the v700 or something similar is how are you going to get the discharge cute of the windlass over the rope locker. A common alternative is to use a vertical windlass mounted horizontally inside the chain locker with the rode dropping off the gypsy right into the locker.
1/4 is sufficient, but make sure it has "G40" (HT) stamped into each link....really just need to know if 1/4 chain and this windlass is big enough for a 25 lb anchor and 30 ft 1/4 chain
