Zinc Anode
6
S2 24 Swampscott
Hi,
I have an S2, 7.3, 24 footer. I would like to know if there is a zinc anode anywhere on this boat.
Thanks in advance,
A novice
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Need a little info? Inboard, outboard or saildrive? All should have a zinc or zincs.
Feb 26, 2011
1,428
Achilles SD-130 Alameda, CA
Boat undoubtedly came from the factory with no zincs. If one has been added by a PO, it would probably be on the keel. But honestly, you don't need one on that boat.
BobM
Jun 10, 2004
3,269
Actually
Most outboards have zinc anodes on them. You don't really have to worry about it though, as long as you don't leave the engine in the water. If it will stay in the water when you aren't sailing you definitely need one. Even my Suzuki 4hp has one. Many times they are located above the prop on the underside of the horizontal fin.
