ZF 12m 2:1 Question
CYQK
Sep 11, 2009
610
beneteau first 42 kenora
Need a new gear for our boat.Problem is no one has a gear with 2:1 ratio available because of supply chain
One supplier has a new one but it is a 2.6:1
Anyone out there have experience to know if changing from 2:1 to 2.6:1 will be a dissapointment
Thks
Gary
Things have changed since summer. In summer it was the other way around, no 2.6s and just 2.1s.
We replaced our Kanzaki with a 2.6 last summer. The prop will need to be changed either re-pitched if it has an adjustable pitch or replaced if it is a fixed prop.
Also expect to replace the mounting plate, flange (get a split flange), mounting bolts, and transmission cable. While things are apart replacing the damper plate is probably a good idea.
Likes: kloudie1
CYQK
Sep 11, 2009
610
Surprise.......
Called all over north america yesterday and majically 2:1 appeared. Same places i phoned last fall that had none
Good news!!!!
Likes: LloydB
