z spar mast number
Jul 31, 2013
1
oday 192 charlevoix
Hello, I,m dealing with a broken mast hinge on my 192 and need to know the z-spar mast section number (z145 or z170)or mast section dimensions. thanks and fair winds Dave
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Qeaflex, check out www.rigrite.com
You probably need a Z-1112 deck plate, which fits both the z145 and z170 section.
If it's your mast foot that needs replaced, you can find section dimensions here: http://www.rigrite.com/Spars/Zspar/Z_Mast_specs.html for both the 145 and 170, and you should be able to measure your existing mast to determine which it is.
And then hope it's a 145, because it looks like feet for the 170 are no longer available. The Z-145-SF foot comes in different sizes - which should be heights, in case you needed to cut some of the foot of the mast, you could get a taller foot so that you wouldn't have to shorten your rigging.
I couldn't tell you directly which section you have, as I have a Dwyer mast.
Brian
Nov 8, 2010
11,386
Why not just call US-Spars? There ARE Z-spars in the USA.
Contact
386-462-3760
800-928-0786
386-462-3448 fax
US Spars Inc.
6320 NW 123rd Place
Gainesville, FL 32653
