Hello all. Hauled out the boat yesterday. It does not look too bad. The yard told me about a bottom paint removal process through blasting a substance that clumps as it removes, costing around $2,000. Also have any of you used a bottom paint stripper? What system do any of you recommend? What total process would you recommend? Also, there is some groinding damage to the bottom front of the keel. It looks like a bit of filler was broken off showing the lead. What is the best repair method to perform. Here is some pics, one showing the failed prop
