YSM12 Transmission
406
Cal 25 mk II T-Bird Marina, West Vancouver
I have a question regarding the transmission (reduction gear & clutch assembly) for a Yanmar YSB, YSE and/or YSM. Those that have one of these simple and reliable single cylinder horizontal diesel motors with will know that they came in both the 8HP and the 12HP variations. The transmission gears are in constant mesh and uses a wet type single-disc mechanically operated clutch using 0.7 Litre of engine oil. My Yanmar is a 1979 YSM12 with a 1.976:1 reduction ratio in both forward and reverse with a Campbell Sailor CS3LH12x7x1 propeller. Now that you have the back ground, here is the question that everybody asks but few can give an intelligent answer.
With a YSM12, should you leave the transmission in gear or in neutral when sailing?
I am not looking for a lecture about hydraulic shifted transmissions using automatic transmission fluid or look the manual or is it a Kanzaki. I have the Yanmar shop manual and nowhere in it or on the motor/transmission does it say what the transmission make or model number is other than Yanmar YSM12. I also searched on the internet and not found anything useful. I'm looking for information from YSB, YSE and/or YSM owners.
Dec 2, 1999
15,184
The only down side of putting your transmission in reverse while sailing is the drag. I am sure that the drag with your CS vs a regular Michigan is considerable less.
If you are in doubt, put it in reverse until you get an answer from a certified Yanmar dealer that it is OKAY to sail in neutral.
Maine Sail has a presentation on the subject. But the real question would come from the mfg. I would contact the master distributor in your region for the answer.
PS: What type of speed do you normally get out of this setup? Did you have another prop on this boat before you got the Campbell?
Beneteau 323 Annapolis MD
Jal, you've listed three different engine models and two different horsepower, and I would have to believe there could have been more than one type of transmission over the period of years this(these) engine(s) were in use. Since you can't find any mfg info on the tranny, can you get us a picture to look at? Might be the only clue left?
Oct 17, 2004
144
Seafarer 30 Paris Landing
I have the original YSM Operation Manual. There is no information on this question in the YSM Operation Manual.
Jun 2, 2004
5,802
I would be interested to know how it has lasted for thirty years if it is original. How did the other owner(s) sail the boat?
2,288
C30 Event Horizon Port Aransas
It doesn't matter if you leave it in neutral, reverse or forward becasuse of the way the gears are lubed.
I asked the same thing a week or so ago. The reason why some manufacturers tell you to put it in gear is they don't want the transmission turning without the oil pump supplying lube oil to the gears. But on the YSM the gears are lubed with the turning of the gears in a bath of oil.
Feb 4, 2005
524
Catalina C-30 Mattituck, NY
I would agree with Scott on his point above. I leave mine in neutral its its over 30 years old. MackBoring has a great tech line for Yanmars, particularly the YSM series. try giving them a call at 866.526.9717.
- Rob
Transmission position
Since this comes up so often, I "tagged" the last topic, the one Hermit mentioned, with the phrase "transmission position."
This is what comes up in a search for that exact phrase: http://forums.catalina.sailboatowners.com/showthread.php?p=678220&highlight=transmission position
It's a pretty good discussion in answer to your question, and should be pretty handy for the future, too. It's got some good links to other discussions.
Good luck finding the documentation you need.
Mar 2, 2008
406
Steve:
- I have been leaving it in FWD to reduce ware on the stuffing box.
- The CAL 2-25 has a 22'0" water line length and a hull speed of 6.5 knots. I get about 6 knots at 2800 RPM (full speed is 3000 RPM) and use less than 2 Liters per hour.
- She came (Spring 2007) with a three-blade CS3LH13x9x1 which was way over propped and could only get up to about 2400 RPM at full speed. Sank the transom, used lots of fuel and had major overheating problems. I then installed the spare two-blade CS2LH12x8x1 and could get about 5 knots at 2800 RPM. Campbell Sailor recommended machining /adjusting the three-blade prop to a 12" diameter and 7" pitch. They are a local company and only charged CDN$50 for the service. The CS3LH12x7x1 looks like the best propeller for my CAL 2-25 with the YSM12.
Hermit & Rob:
- Thanks, that is what I suspected. The three-blade Campbell Sailor design has less drag and more propulsion then most fixed two blade props.
Dec 2, 1999
15,184
Jal: This is interesting to hear. We have a friend with the same motor in a Hunter 30. He also needs to do something about the prop. I am going to forward your information to him for evaluation and see what he says. Thanks for the input.
I believe that you will find that the "preferred" method for locking the prop is actual reverse, but if forward resolves your issues then OK!
2,288
Steve:
I thought about that, but if your engine is doing 3000 revolutions per minute while -powering, how many revolutions is it going to do while sailing along and letting the water spin it? I don't know, I am sure Maine Sail could tell you; he has done some testing on this subject.
But my guess is if you motored a half an hour, you would have to sail for a week straight to achinve that many revolutions of the prop shaft. And it would be at a MUCH lower RPM with much less heat to aid in wearing the stuffing box. It has to be negligible. And aparently according to a recent study you sail faster in neutral. But not everyone can sail in neutral or it kills the tranny as discussed in the link Stu provided.
Mar 2, 2008
406
Hermit:
- The gear box ratio is about 2:1, 3000 motor RPM is about 1500 shaft RPM. I can't measure shaft RPM but when sailing in neutral at about 4 knots, it looks like the shaft rotates about three or four times per second. My guess is a couple of hundred RPM.
Dec 23, 2009
2
Catalina C30 Ventura
leave it in gear with the prop straight up and down for the lowest drag under sail. If you are having trouble with boat speed ,I hav aC30 and that proponly gave about 4.0 knots under power .Iswitched to a 12/10 2 blade and it worked much better panache tony
Mar 2, 2008
406
Tony:
- Boat speed / prop drag is not an issue with the Campbell Sailor prop. If you read my inital post you will see that I'm using a three-blade prop. I have been just leaving her in FWD when I stop the motor and probably will keep doing that.
Feb 6, 1998
11,772
Yanmar to my knowledge has never stated in any of their manuals which position to put the gear box in for sailing. I had a Y series engine in my old C-30 and was told by Gordon Torresen to either leave it in neutral or lock it in reverse but not forward. I only found out after wards Gordon was wrong and Yanmar advises now that it should be neutral. I know of no gear box maker that suggests leaving it in forward but this does not mean some can't be locked this way I just don't know of any.
I have the entire slew of YSM manuals, including the gear box manual, in PDF form. PM me your email and I will fire them off. These manuals are like GOLD!!;) If you want to lock it I would suggest reverse as Gordon suggested to me many, many years ago..
2,288
Tony,
Do you have a YSM12 in your C30? I have been messing around with michigan 3 blade props trying to find the richt pitch. I am using a 12LH10 currently. I can motor at 5 to 5.3 pretty well even in some chop. I had a12LH11. With that I have had the boat over 6 knots in very flat water and perfecftly clean bottom and prop, after just leaving the yard. But when I hit chop, I could be doing 2 knots or worse.
what brand of prop are you using and what different props and pitches have you used?
2,288
I know the CS prop reportetly creates more thrust than a michigan prop, but that is interesting that you are using a 7" pitch! If I put a michigan 7" pitch on my boat I suspect I would find top speed at 3 knots, but could plow through the perfect storm at 3 knots also. Those CS props are definitely a different animal.
Mar 2, 2008
406
Hermit:
- My YSM12 has the 2:1 gear box ratio that produces a maximum 10 shaft HP at 1500 shaft RPM. My sailboat has a water line length of 22' 0", beam of 9' 0" and displacement of about 5000 lb. These are the parameters plus experience that the Campbell Sailor people used to recommend the 12" diameter and 7" pitch with their 3 blade prop. The original 13" diameter and 9" pitch was way over proped. They said that one inch of diameter has a similar effect as two inches of pitch. I think the cup in their blades give it extra thrust. They also said that they would adjust the pitch for free if I was not happy with it. I am glad it works well because at my marina it costs me about CDN$150 for a "half lift" required each time I replace the prop. I have no experience with other fixed props.
2,288
I have the exact same engine as you. But my boat is 10,200 lbs. soemthing like 26' on the water, 11' across the beam. (Not exact but close)
what kind of speed are you getting with your new prop?
I scuba so, my prop changes are free. Except it's getting a bit cold with out a wet suit for me.
