I'm hoping there is still a few knowledgeable YSM12 people around because I'm stumped!!!! My engine was totally rebuilt two winters ago and a rough guess is it has about 100 hours on it. All bushings and bearings and every part imagined was replaced. After runnung for around and hour at around 2200RPMs(4.5-5kts)my oil pressure is down around 10 psi. If I reduce throttle to 800RPMS(idle) my pressure drops significantly and my alarm begins to chirp. I removed the connecting rod bearings and plasti guaged it and it was well within specs and the bearing surface was perfect. Today I installed a new oil pump gears, oil pump cover plate and O ring. I had the machine shop install a bushing for the oil pump shaft in the aluminum cover which was just a bit out of tolerance. Installed new W30 oil and took my Hunter30 for a run. Same problem!!!!! Once the oil gets hot and thinned out, pressure drops. I installed a new raw water impeller and ensured the raw water filter was not clogged(engine not overheating)
What are the symptoms if the crank case ventilation cover plates are installed wrong(I seen mention of it in the archives)
What about using a thicker oil (20W40)??????
Any thoughts would be greatly appreciated....Thanks
