YSM12 filter recommendations and priming advice
Hunter 30_74-83 Rochester, New York (Lake Ontario)
Ahoy,
I am changing the primary and secondary fuel filters on my YSM12 this week. Any recommendations on the primary (2, 10 or 30 microns) and words of wisdom on priming, bleeding the system after the filter replacements?
Thanks,
Bob
1979 Hunter 30
"Summer's Glory"
Home port, Rochester NY - Lake Ontario
RAD88
Dec 15, 2008
163
Hunter 30 Glen Cove, NY
Ahoy,
Thanks,
Bob
1979 Hunter 30
"Summer's Glory"
The small one on the engine should be 2 microns and the Racor should be 30 microns.
As for bleeding - if you have an electric fuel pump just turn the key to the run position. You should hear the pump clicking, then back off the screw (at the end of the braided hose in the picture) until fuel starts escaping then tighten up again. On the little Yanmars its pretty easy. When you are finished mark the bleed screw with a dab of bright paint so it is easy to remember if you have to do it on the water.
Don't forget to turn off the key when finished.
garyc
Oct 4, 2008
63
Hunter 27-76-84 mallets bay,vt
cut in an outboard priming bulb in the fuel line between filters.
