Steve
After our last discussion, I went back and cleaned the sockets for the bulbs and I now have 2 of the 3 lights working when the key is turned to the left (I presume this is a test position) the third light that won't glow is probably the high heat light that shoudn't ground in the test position anyway. When I go to start the engine, shouldn't the bulbs light before I start and stay lighted until the engine is running. I also found two unattached leads that have with power in the " test position " and I think they may be for a departed buzzer. Could someone tell me how the warning system works on their boat. It will make it easier to fix if I know how it is supposed to work. Thanks in advance, Steve.
