Check the archives
There was a recent post abt. lubricants that got a lot of responses: I think it was on this forum. The idea was kicked around pretty well and seemed to cover most of the issues involved. Steve identified that selection of an oil is often a matter of availability and not necessarily a suggestion that one product is superior to another. I'd say that any oil from an established, reputable, refiner that carries the correct API service classification and SAE viscosity number would be OK, but both the API & SAE data have to meet or exceed the spec. given by the engine mfg. CE is "better" than CD; CF "better" than CE, and so on. Older engines were designed before multi-grade oils were readily available, so their spec. will call for a single weight oil, say a SAE 30. A multi-grade oil would usually be an acceptable substitute and probably is more readily available, but there may be a few exceptions to this. Bear in mind that when two numbers appear for the SAE viscosity, the first number refers to the cold start viscosity and the second, the viscosity at operating temperature.So if the engine calls for a SAE 30, then a 10W-30 should perform the same and have the same properties when hot, but a 10W-40 may be too "thick".Don't know abt. API CH-Plus or CI-Plus, but if you're using a LSD or ULSD fuel I'd contact a distributor or the oil co. and ask abt. compatibility of your prefferred oil to the fuels.
