Bed-It sounds like great stuff to use but I have a couple of concerns/questions. I'm interested in comments from @Maine Sail as well as unbiased opinions from others
- When fittings are tightened the butyl rubber will squeeze out. Will it reach a point where the butyl rubber cannot compress any further? I would assume so because if you squeeze it all out it would no longer form a seal
- One comment on the site mentioned that the Bed-It never stopped squeezing out. Has anyone experienced this? I've used the automotive grade butyl rubber and its very messy stuff
"One problem I've encountered, however, is that the "squeeze-out" phase never seems to end. I have fittings that I bedded 3 years ago that are still slowly pushing out excess tape. I clean off the excess with a razor, and yet within a few months there's more that's squeezed out.
I'm not hugely concerned about the appearances, but once this stuff comes loose, it tends to spread around the boat. You get a loose bit on a control line, or a deck shoe, and the next thing you know there are little bits here and there..."
