Hi all
My yse 12 has a very good compression, the previous owner installed a nee fuel pump on it( the high pressure one). To start it i have to pull hard on the fuel lever on the pump, and the it idle Pretty high, once started it is fine and dandy but the pulling is making it a pain to start. I tried adjusting my control cable to have more tension at full throttle, but anything i do don't work and just get my idle speed higher.... Tired of friggin on it
Anyone ever had this problem before?
