Avast mates!
I am shouting out for some advice re. my Yanmar YSB12. I blew the head gasket and am now in the process of reeinstalling the head and the new gasket.
My understanding is since this is a "pushrod" engine with no timing belt or chain and with the valve adjustment untouched I can simply pop the head back on without reestablishing timing.
I am concerned that when I put the pushrods in place, being careful to insert the ends into the little cup shaped part that rides on the cam inside the block and the other end of pushrod in the rocker arms.
At this point I checked the gap on the rocker arm and it's like 1/4 inch. The gap should be set to 0.2mm. Before I took things apart the engine started very, very easily and ran great but made steam.
I expected not to have to adjust the valves at all, but now I see a 1/4 gap as if the pushrod was not mounted correctly or was too short.
Any ideas what I am missing???
Thanks to all, in advance for any forthcoming assistance.
God Bless America.
