Yanmar part 2
Had to send the previous message to keep from getting cut off.The Yanmar valve cover has a neoprene O-ring seal vice the cork type so it is re-usable, a nice feature. Ditto the seals on the heat exchanger.Yanmars do not like to be idled either for charging batteries or motoring long distances in no-wake areas; they like to be run at about 2850 RPM minimum (for the 3GM30) to prevent carbon buildup in the cylinders.Starting is without glow plugs but use a good battery and the engine cranks and starts easily, even in near freezing weather. Never use starter fluid, especially in a diesel.The 3GM30 should be the perfect size for your boat.There you have it, and if I think of anything else I'll add it.
