N
Nils Andersen
I have a Hunter 27 with a Yanmar 8SB diesel.While motoring out of the marina the boat suddenly lost propulsion. The engine was still running, put the prop was obviously not turning anymore.After being towed back to my slip, I checked thatA: the prop was still there (although I don't know if it could be slipping)B: I could not see any movement of the prop shaft where it attaches to the transmission.1. What could be causing this?2. What is required to remove the transmission? Does the prop shaft have to be pulled?
